Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 4771 / Visits Today: 4250
Highest Active Users: 4771
 Another new toy
Previous Page | Next Page
Page: of 3
Denny
Posted - 02/05/2010 :  20:25:19  Show Profile  Visit Denny's Homepage Send Denny a Private Message  Reply with Quote
Slippage,, belt was bouncing,, due to lack of pressure. It just seems to me,, that the replacement belts,,(and original on mine) are about an inch to long. I say this because,, even after mods to take up the slack,, my belt almost rubs the rear axle. And this would explain why the idler is maxed out in stock configuration.
Won't be the first time the engineers missed something.
Early B10
67 Bee10
68 B16HD 112 Loader
68 B112 L112
68 B112
4041 Power Max
jim390fe
Posted - 02/05/2010 :  21:08:03  Show Profile Send jim390fe a Private Message  Reply with Quote
Thanks for the info Denny, I have some spare time tommorrow (Saturday) I'll check it then, and let every one know what I come up with. Hopefully It'll be good news with a just a simple adjustment.
1966 A-C "Bee" 10
1967 Simplicity 2012 landlord
1967 simplicity 3012 Sovereign
1969 Simplicity 3112H
Sovereign
Posted - 02/06/2010 :  10:00:24  Show Profile  Visit B-16_IC's Homepage Send B-16_IC a Private Message  Reply with Quote
All the variables I have have no paint or grease on the right axle tube, they have all rubbed. The B-210 is quite shiny. I agree, something was missed there.
Posted - 02/06/2010 :  13:28:44  Show Profile Send skunkhome a Private Message  Reply with Quote
My Shuttle and Variable both have shiny axle tubes. Don't like it much but I guess it really doesn't hurt. The old 3 speeds like the B10 and B1 had a different set up where the idler pushed up on the belt to engage the clutch where the Shuttle and Variable work the opposite way.
Edited by - skunkhome on 02/06/2010 13:29:16
jim390fe
Posted - 02/06/2010 :  18:15:20  Show Profile Send jim390fe a Private Message  Reply with Quote
I got a chance to fiddle around with mine today, same thing you guys are experiencing, what seems to be a sloppy belt that you cant adjust enough, and a shiny axle tube to boot! I thought about getting a new belt, but mine measures 53 3/4" and new ones cross out to be a 54" belt, so I don't think it'll help that much plus at $60 a pop I dont want to take a chance! This is my first vari-drive tractor, I like the regular 3 speed setups (typical on the round hood models) and the hydro on my Sovereign, but I'm starting to think maybe the variable drive wasn't the best idea they had.
1966 A-C "Bee" 10
Sovereign
Posted - 02/06/2010 :  20:33:27  Show Profile Send skunkhome a Private Message  Reply with Quote
Jim, I'm kinda with you but I do know they work as we had a brand new 312D which was a variable. The thing that I did not like about it is it tended to loose traction in the low ranges. If you wanted to pull a heavy load they recommended you use a lower gear range and run the variable in the higher ranges.
jim390fe
Posted - 02/07/2010 :  05:36:15  Show Profile Send jim390fe a Private Message  Reply with Quote
Phil, Is there any way to change the geometry of the belt to get it away from rubbing on the axle tube, and still be able to run through the ranges? I dont think that it would be any good over time as these axles tend to have a weak point on that side near the outboard differential.
1966 A-C "Bee" 10
Sovereign
Posted - 02/07/2010 :  12:54:46  Show Profile Send skunkhome a Private Message  Reply with Quote
I am sure there is a way but I am sure Simplicity would have done it differently if it had worked well. Let face it they went through a great deal of effort to reverse the action of the idler on the vari-speed and the shuttle, introducing more slop and creating additional parts on the idler assembly alone. I have been thinking that it needs a belt guide to just keep the belt from going through those huge oscillations while running. After all the belt does not touch the axle when the belt is stationary. But when you think about it my B112 is 43 years old and it is probably the original axle tube and it is not cut just polished.
jim390fe
Posted - 02/08/2010 :  20:30:34  Show Profile Send jim390fe a Private Message  Reply with Quote
Had another chance to try out the vari-speed on the B-112 today, Its seems like is driving and plowing fine. adjusting these are definately a compromise... if you turn the adjustable turnbuckle to shorten it too much you lose the low range through the adjustment, make it too long it'll get too sloppy and start to slip, and there is a fine line between these adjustments to find that sweet spot! (Like most things I guess). I believe most of my problems lie within my clutch return spring, it is too weak to engage the belt, (I have to manually pull the clutch pedal back with my foot) and the bushing for my idler arm & pulley is worn out (creating more unnecessary slop). Once I get those things corrected I think I'll be in pretty good shape. (I hope )
1966 A-C "Bee" 10
Sovereign
Posted - 02/08/2010 :  21:45:08  Show Profile Send skunkhome a Private Message  Reply with Quote
Jim, sound like you could be standing thre looking at my tractor describing the clutch. Just way to much slop.
Denny
Posted - 02/09/2010 :  07:48:41  Show Profile  Visit Denny's Homepage Send Denny a Private Message  Reply with Quote
Shorten that rod up,, it will add spring pressure , and in turn add idler pressure,, I promise ,,lol
Even a half inch will make a big difference.
Early B10
67 Bee10
68 B16HD 112 Loader
68 B112 L112
68 B112
4041 Power Max
Posted - 02/09/2010 :  09:07:08  Show Profile Send skunkhome a Private Message  Reply with Quote
I have some rod stock. It might just be better to make a new one.
jim390fe
Posted - 02/09/2010 :  09:56:00  Show Profile Send jim390fe a Private Message  Reply with Quote
Thanks, I'm going to have to try that, but like Phil said, I might make it from scratch from some rod stock I have this way if I screw up I'll still have the factory one to fall back on, lol!!
1966 A-C "Bee" 10
Sovereign
Posted - 02/09/2010 :  15:10:53  Show Profile Send skunkhome a Private Message  Reply with Quote
another idea is to make a new one cut it in two and thread it for a turnbuckle so that I can make it adjustable.(don't know where to get a LH die)
Edited by - skunkhome on 02/09/2010 15:11:57
sleepy
Posted - 02/09/2010 :  20:22:47  Show Profile  Visit sleepy's Homepage Send sleepy a Private Message  Reply with Quote
Phil any good machine shop can do this with their lathe. Powering out will give you left hand threads. Alan
