Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 1747 / Visits Today: 1747
Highest Active Users: 1747
 finished new tank
Posted - 09/02/2010 :  21:35:18  Show Profile  Visit snohiker's Homepage Send snohiker a Private Message  Reply with Quote
well its done except for paint think ill wait till i paint the whole thing
Posted - 09/02/2010 :  21:58:21  Show Profile  Visit acb10_64's Homepage Send acb10_64 a Private Message  Reply with Quote
My hats off to ya! Nice work! I would've messed up trying to weld that up.
Posted - 09/02/2010 :  22:15:05  Show Profile  Visit snohiker's Homepage Send snohiker a Private Message  Reply with Quote
well i did have two leaks if you look at it on the table two arrows
Posted - 09/02/2010 :  23:33:29  Show Profile  Visit acb10_64's Homepage Send acb10_64 a Private Message  Reply with Quote
What welder/ welder type are you using??
thepatriot
Posted - 09/03/2010 :  06:32:27  Show Profile  Visit thepatriot's Homepage Send thepatriot a Private Message  Reply with Quote
Great work!
AC B10-Simplicity LL101,7010,7110,7790DIESEL
Posted - 09/03/2010 :  08:15:10  Show Profile  Visit larry8200's Homepage Send larry8200 a Private Message  Reply with Quote
As they say, "Necessity is the mother of invention". Nice job.
gearhead19
Posted - 09/03/2010 :  08:50:03  Show Profile  Visit gearhead19's Homepage Send gearhead19 a Private Message  Reply with Quote
Looking good, How did you pitch the thread for the cap?
Dan
Posted - 09/03/2010 :  10:25:29  Show Profile Send Cvans a Private Message  Reply with Quote
Very nice work. I'm guessing that you used a tig welder.
Chris
Posted - 09/03/2010 :  17:17:57  Show Profile  Visit snohiker's Homepage Send snohiker a Private Message  Reply with Quote
yes its tigg and the fill and tap are from the old tank i soldered them back on this tank luckily in the right spot just need to put the dent in the side of it for the side panel bolt now i think im going to heat that spot rely hot and press it in
Posted - 09/03/2010 :  22:36:24  Show Profile  Visit freddie's Homepage Send freddie a Private Message  Reply with Quote
GOOD JOB SNO.
Gray
Posted - 09/04/2010 :  03:17:29  Show Profile  Visit Gray's Homepage Send Gray a Private Message  Reply with Quote
looks great, snohiker
I wish I had welding gear. and the know how to do it.
ALLIS CHALMERS 716H
SIMPLICITY Pacer 1334
Posted - 09/04/2010 :  08:36:28  Show Profile  Visit B112's Homepage Send B112 a Private Message  Reply with Quote
That was a nice job. This is a first I've seen someone make their own gas tank.
Posted - 09/04/2010 :  09:30:53  Show Profile Send oldron a Private Message  Reply with Quote
Nice job! With my welding it would have been a better sprinkler system.
Posted - 09/04/2010 :  10:22:18  Show Profile  Visit snohiker's Homepage Send snohiker a Private Message  Reply with Quote
thanks guys my dad thought me well
Posted - 09/04/2010 :  13:51:07  Show Profile  Visit simplelife's Homepage Send simplelife a Private Message  Reply with Quote
With those fabricating skills, I can see a new challenger to "American Chopper". Snohikers Custom Tractors! Ground up custom builds, Excellent work. I now realize why my talents are limited. Some people evidently got others share of talent!
Gray
Posted - 09/05/2010 :  15:04:58  Show Profile  Visit Gray's Homepage Send Gray a Private Message  Reply with Quote
I am constantly envious of people with welding equipment and the skills to use it. I would like a welder and a free pass to "get over the learning curve free". /p
In highschool, I took a brief welding course, half semester kind of thing. I learned mainly that my classmates were real jokers who always cranked the voltage settings to the max, causing excessive spark showers, and other forms of terrorism. On the acetylene scene, I got real good at burning holes in metal. The course ended when I started to almost improve. (sigh).
I think about getting a basic arc welder - don't know anything, if that would be a good solution. They seem cheaper. I was always fascinated by the power side of this - big bright light, high heat, gluing steel to steel permanently. Another skill I admire is machinist. And fabrication. Welding seems the hot item for tractor fabs. And I have steel lying around in my garage, and can't do much with it other than cut and drill and file and grind and bolt. That's handy; but welding = priceless. Lots to learn; how to get there. Maybe it's not so out of reach.
ALLIS CHALMERS 716H
