Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 10438 / Visits Today: 1742
Highest Active Users: 10438
 First Bargain of the year.
mikeman Posted - 03/14/2017 : 11:07:32
Vanguard 18hp v twin from a generator. $50
Cvans Posted - 03/27/2017 : 14:32:35
Could you cut the tapered end off and have a usable straight shaft? Would make it easier to use as the PTO.
mikeman Posted - 03/27/2017 : 14:13:23
Engine sure looks clean. You have an adapter housing on that engine. If you were to take that off would you have an extra long shaft?
Extra long shaft that housing is for the generator coupling.
Cvans Posted - 03/24/2017 : 20:34:47
mikeman Posted - 03/20/2017 : 10:02:36
Nice find. Did you get the shaft (hub) from the generator to use for an tapered adapter?
All I got was the engine, muffler and control panel with regulators.
The engine will drive from the flywheel side so I will need an adapter for that and maybe a gas carb.( Propane 7117h?)
First run on propanehttps://youtu.be/UFGDALvIzFQ
skunkhome Posted - 03/15/2017 : 01:38:22
Two thumbs up.
Cvans Posted - 03/14/2017 : 20:06:00
B-16_IC Posted - 03/14/2017 : 19:31:13
50 is definitely a bargain! Hours are low,I'd love to put that in a tractor.
