Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 5524 / Visits Today: 5524
Highest Active Users: 5524
 314 Rear hitch
jay2_45644 Posted - 03/27/2015 : 18:48:52
I need to make a rear ball hitch for my 314. Any picture's or thoughts available here? Thanks Jay.
jay2_45644 Posted - 04/05/2015 : 10:51:54
Ok I put a video of it working on you tube.
https://www.youtube.com/watch?v=jSUMKy0SDkc&feature=youtu.be
jay2_45644 Posted - 04/05/2015 : 06:55:51
The up/down movement seems fine. I added the stop bar on it so it won't slam forward. All seems lined up good. The rains have stopped so maybe I'll take it out and try moving something with it soon.
skunkhome Posted - 04/04/2015 : 01:01:28
Looks good. How's it working for you?
jay2_45644 Posted - 04/03/2015 : 21:02:16
Ok. Done. Not perfect, I tried to use the info and pictures from this site for my rear ball hitch. Thanks for your help. Pic attached.
skunkhome Posted - 03/29/2015 : 18:20:33
I got one of those from Roy and ended up giving it to my brother in Indiana.
jay2_45644 Posted - 03/29/2015 : 11:49:43
I Like the third option. I'll give it a try.
Thanks, it helps to have a site like this with members who can help out.
Jay
skunkhome Posted - 03/28/2015 : 21:29:39
This might give you some ideas. A word of caution is warranted on pulling heavy loads on a ball above the rear tractor axle. http://www.michaelstractors.com/forum/topic.asp?TOPIC_ID=5654&SearchTerms=Roy,pope,ball,hitch
http://www.michaelstractors.com/forum/topic.asp?TOPIC_ID=2834&SearchTerms=Roy,hitch
http://www.michaelstractors.com/forum/topic.asp?TOPIC_ID=2024&SearchTerms=Roy,hitch
jay2_45644 Posted - 03/28/2015 : 13:53:11
Thanks' Phil. What should I build? I can't find pictures. Surely most have a ball hitch to pull with. Thanks for any help.
Jay
skunkhome Posted - 03/28/2015 : 10:10:43
Btw that hitch did not work. The lift rod was way too far out on the lift lever. Took three men and a little boy to lift the implements. I moved the lift point about 1/2 the way in and it works fine.
The only problem with a ball on the hitch is that without a positive stop the tongue of a trailer will slam forward and up upon braking. Not stable on a 7000/700 series with its cable lift but could work on a 300 series since there is a solid link between the rock shaft and the lift lever if the slide feature were eliminated.
jay2_45644 Posted - 03/28/2015 : 08:58:39
If I made one like the picture. Could I put the ball where the arrow points, would this work? Found this picture of Phil's toy on this site.
