Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 1081 / Visits Today: 1081
Highest Active Users: 1081
 Big and little Allis workout
split51 Posted - 12/08/2012 : 19:04:07
The 17 and 112 got a workout in the gravel. I had 60 tons brought in total. The 17 moved it and i used the belly blade on the 112 to smooth it and then dragged the tires around to finish.
( I noticed the wall of my soon to be carport looks like they are leaning, it is just my camera phone throwing it out of proportion.)
Talntedmrgreen Posted - 12/10/2012 : 07:51:19
Thanks for sharing Jeff! Lots of work there...nice to find uses for the old AC =]
split51 Posted - 12/09/2012 : 16:31:20
Here are a few more random shots.
olcowhand Posted - 12/09/2012 : 14:19:26
Quite the improvement!!!
split51 Posted - 12/09/2012 : 13:53:22
Daniel. I have an AC 621 all terrain forklift that i used to set the blocks.
I used about a foot of gravel for a base on the blocks. I rented a trackhoe to remove the trees and dug the hillside out and cut a trench for the gravel base.
Phil. I used railroad ties to divide the grass from the gravel on the downhill side. I backfilled dirt up to the ties so i will be able to mow it easy.
used the belly blade to cut into the up hillside going up the left side of the blocks and pushed the gravel up to the edge of the cut.
My buddy that hauled the gravel called it crusher run. I do not know is it is limestock or not.
Here is a picture before i started standing in about the same place as the first pic above.
Here is a pic standing about the same place as the 3rd pic above.
skunkhome Posted - 12/09/2012 : 09:11:37
I suppose .the "gravel" is crushed limestone. I'm impressed with how straight your borders are.
olcowhand Posted - 12/09/2012 : 08:38:13
What kind of base is under your walls?
olcowhand Posted - 12/09/2012 : 08:37:36
I forgot what you said you used to lift those block? I have finished lining the walls of 2 large silage pits, and one side of a 3rd one with the identical block.At this point, I've used about 650 block.
First pit in use:
2nd pit walls complete, behind loader to the left.
The retaining wall directly behind the loader now is extended to the right, which forms the one wall we have completed on the 3rd & final pit. We need 45 more block to finish the other side of this pit. We should have enough in a month or so to finish, then pour new floors in the spring.
B-16_IC Posted - 12/08/2012 : 23:36:03
That looks like fun, at least the spreading part. The paying part, not so much! Looks like the pair did a fine job of the task. You've certainly made some major changes there!
skunkhome Posted - 12/08/2012 : 20:10:52
Gee the scale is so large it looks like toy tractors.
