Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 7494 / Visits Today: 7494
Highest Active Users: 7494
 Used Five Tractors In One Hour
larry8200 Posted - 09/07/2012 : 13:14:01
Redoing a bad spot in my lawn where the sun always cooks it, and removing an old fence while I'm there.
I used:
3416H puller to pull out fence, and then the B-210 when I got it stuck..
3212H Weedcutter to clean up around bushes
3416H Dozer to start leveling/grading
B-210 with 10" Brinley Moldboard
And a 3415S with cart to pick rocks.
Now I got to go mow with the other 3212H. :)
ASEguy Posted - 10/12/2012 : 06:57:34
In this case I think the B stands for Beast! Be careful, that B may bury itself. Gotta love the torque.
skunkhome Posted - 09/08/2012 : 21:25:48
I think few in the deep south have any acquaintance with basements.
larry8200 Posted - 09/08/2012 : 13:24:50
Originally posted by Cvans
Phil, we get temps down in the -30 range and have no problems with out buildings on slabs. It's the ones that get heated and cooled in the winter like my shop out back that start to break up and that has taken many years of abuse. Homes on slabs is something I have no experience with and can't comment on but our 20 year old garage still looks very good.
Yup, when everything freezes and heaves evenly there isn't a problem. Thankfully we usually only have a 2 week stretch where the temperature gets down into the -20's to near -30 every night. Cold!!
But I wouldn't build anything with drywall or anything nice on a slab.
Cvans Posted - 09/08/2012 : 12:50:37
larry8200 Posted - 09/08/2012 : 11:33:34
We build garages on slabs, if all the topsoil is removed down to gravel, sand, or bedrock, then good gravel added as needed to bring back to proper grade and insure good drainage, then some good re-rod and/or re-enforcing mesh in the concrete to keep cracks from opening, the slab can last aslong as the building.
I am on a gravel base with a foot of topsoil give or take, and my shop built on a slab in 74 is in great shape, although the ground heaves unevenly and the latch on the front door usually misses the striker in the middle of winter. One more of the million little things that never get done.
Daniel, I thought there was to little topsoil but it looks like the soil is depleted there and just wont support thick turf that can withstand the summer sun. I am going to grade it out so its easier to mow, add some "nutrients" and re seed in October.
skunkhome Posted - 09/08/2012 : 10:42:38
If you poured a slab to park a car on how long would it last in that environment?
olcowhand Posted - 09/08/2012 : 10:26:48
Once the ground is worked up well, what are you doing to it....new grass seed, or something else entirely?
larry8200 Posted - 09/08/2012 : 10:14:32
Plowing in rocks, careful you don't break your coulter. I understand that they recommend removing the coulter when you are turning rocks. Of course it will rip the sod pretty badly rather than cut it. Is it true that rocks work their way to the surface each year as a result of the frost. This is all foreign to me as we don't have rocks and have a frost line of 2 inches.
Wow, 2" frost line...
Building codes here specify permenant structures have five foot frost walls to prevent damage from frost heaves. Used to be four feet, but water lines at 4' that dont get used continuously (like a town water main) will freeze on a cold winter with no snow coverage for insulation.
The picturesque New England stone walls are the result of hundreds of years of picking the spring rocks from the fields before plowing. I have had a loader here twice working on my walls and its back breaking work no matter what.
I have my coulter set all the way up. With this anemic sod I'm turning up it doesn't seem to make much difference.
And yes! I am getting a nice "crop" of rocks, that are the beginning of a new wall.
I figure the 800' stone wall out front is close to 300 years old, and I consider it a "Work In Progress" :)
skunkhome Posted - 09/08/2012 : 10:00:34
acb10_64 Posted - 09/08/2012 : 05:38:01
Looks like fun! That plow sure comes in handy.
larry8200 Posted - 09/08/2012 : 04:35:13
Wow, those look like very deep furrows. How deep are you plowing?
I think about six inches. I would go deeper but I like plowing in 2nd, and its as deep as the B-210 will pull it without going to 1rst.
Actually, I'm just breaking up the sod before roto-tilling, and a ripper bar would be as good or better, maybe, and would pull much easier. I pronbably wouldn't bring as many rocks to the surface though.
skunkhome Posted - 09/07/2012 : 20:29:45
Cvans Posted - 09/07/2012 : 15:53:11
40 or 50 years ago you would have made an excellent sales brochure for Simplicity. Have fun.
