Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 3743 / Visits Today: 3628
Highest Active Users: 3743
 bgb lol
snohiker Posted - 10/27/2010 : 20:54:27
well finally got into the bgb on the 2010 and this is what i found
this is after i cut the bolt and finally got the shaft to turn
the bolt that holds the pinion gear on backed out and welded itself to the cross shaft witch explains y the pinion shaft was turning and notthe drive shafts lol never would of thought id see that
12   L A T E S T    R E P L I E S    (Newest First)
B112 Posted - 10/29/2010 : 11:44:30
freddie, I swapped out the photo for a 640pixel wide version for the ease of everyone reading this post. If you click on it, you get to your original photo.
freddie Posted - 10/29/2010 : 11:37:36
hey rob heres one on ebay for .99 and 8.50 to ship it. just a thuoght or i can send the one i have.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200534516893&ssPageName=STRK:MEWAX:IT
snohiker Posted - 10/28/2010 : 23:17:46
the long one freddie it the cross shaft thats worn bad the bearing wobbles on the shaft its so worn .i think the bearing was stuck at one point in time and the shaft was spinning inside it
freddie Posted - 10/28/2010 : 22:45:04
heres what i have rob.
(click for larger image)
(Note: Edited by B112 at 12:43PM on 10/29/2010 for smaller picture)
freddie Posted - 10/28/2010 : 22:21:48
i have the short shaft that goes to the drive shaft. p.m. me and will get you back together.
snohiker Posted - 10/28/2010 : 19:01:00
well got a good look at the parts tonight ive got one good case two good gears and the pinion shaft with bearing is good the stock (short) shaft is worn were the bearing rides so its junk the needle and bearing on the other side are full of old gear so there junk as well so the shopping list is two bearings two seals and the shaft well get this thing together eventually
1014211 Posted - 10/28/2010 : 11:36:48
I just got myself a spare bgb and tranny for the 7016. Figured I'm running on borrowed time and good luck! The "youngest" tractor I have is 34 years old!
freddie Posted - 10/28/2010 : 05:56:13
well let me no. i have one you can have. just pay the shipping.
snohiker Posted - 10/27/2010 : 22:17:19
oh ya its dry from the cut off tool it now soaking till i get home tomorrow night
snohiker Posted - 10/27/2010 : 22:14:49
freddie i have a second bgb from the vari drive i picked up the other night im going to try to put all good parts in the original bgb the new box has two broken bolt hole someone welded in so the first box is good and gears from second box im hoping i can save the short shaft im going to try and clean up that weld spot in the shop tomorrow . i think it will work fine nothing rides in that spot
freddie Posted - 10/27/2010 : 21:40:55
looks a little dry. do you have the parts to fix it?
B112 Posted - 10/27/2010 : 21:08:26
Interesting. I need to get into rebuilding these. Understanding the correct tolerances and such. I have two machines or more down because of broken BGB's and two with broken axles. I have all the replacement parts to fix these, NO TIME.
This page was generated in 1.12 seconds. Snitz Forums 2000
