Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 3136 / Visits Today: 3136
Highest Active Users: 3136
 7112H Cleaned up
larry8200 Posted - 09/01/2010 : 19:13:39
If it wasn't for the left front wheel... I think I'm going to leave this completely original for now anyway.
This tractor had to have sat in the weeds for a long time. There is virtually no wear on anything, and not a scratch under the seat, and look at the engine compartment... I'm not THAT good at cleaning. Completely serviced the hydro and ran it for an hour, Perfect! (for a Sundstrand)
The 48" deck on the other hand.... needs help probably. More to follow
Gray Posted - 09/03/2010 : 12:36:39
That's another benefit of cleaning - you find all kinds of details. And really get to know the machine - like "seeing" with the hands. It's amazing what we don't see because of how we look, or focus, or discern. I read a bunch of Carlos Castenada books - he described this phenomenon as our "assemblage point", and talked of how we could "shift it" to have better vision, see the impossible, (assemble a better pix) etc.
I found that kinda fascinating - I get into some unusual stuff. There are many ways to see. Even tho it's tractor cleaning, it can be cleaning the cleaner, in a strange way. Welcome to mystic lalaland.
larry8200 Posted - 09/03/2010 : 10:39:45
Somone had replaced the drive belt with one to long and it was right in front of the shrouds forward bolt hole. The back of the belt was also rubbing on a bolt. The print on that belt was still clear so it hadn't been on there long. PO prefers his craftsmen and obviously knows nothing about it, said he took it for a bad debt. Everything on this tractor is great, and at the same time not quite right. I think it was piecemealed. The roller bar on the deck is on backward, the hydro shroud is close enough, but not right ( had to "tweak" it HARD), Engine has no drain plug, light duty LT battery held in place with a tree branch, J8 plug instead of RH10, what looks like a welded crack on the engine block, holes on the engine fan shroud where something was once mounted, wrong bolts on hood, Ignition key was in upside down, the float on the gas cap/gauge has to be pushed through the hole in the tank, but is the same as my OEM cap on my 3400....
But as they say, It all came out in th wash. :)
skunkhome Posted - 09/03/2010 : 09:48:45
I am curious...Why would anyone take of something as critical as a fan shroud and leave it off? I am so glad for you, he still had it.
larry8200 Posted - 09/03/2010 : 08:09:54
The belt is green, actually. It's a Gates power rated belt.
Gray Posted - 09/02/2010 : 23:20:45
Thanks for the descript, Larry. That sounds kinda serious; even professional. The results are amazing.
What kind of belt is oh so nice blue?
Good luck w the deck trials.
larry8200 Posted - 09/02/2010 : 14:40:41
Mr. Gray, A gracious Canook deserves an answer :)
First, I knew very well what you meant. I prefer waffles with fresh butter, myrple syrple, and sliced strawberrys. Sausage or bacon. Stop by!
Second, I dont use pressure washers, I cause enough mischief with a hose. Add large amount of elbow grease between every other word. I warmed it up good to start, and sprayed greasy areas liberally with degreaser. waited half an hour and hosed it down. Started engine and while running I hosed everything while using a wire brush, bristle brush, and rags. Fowled the points here and killed it, oh well. I mixed regular laundry detergent, 1 cap to 1 gallon in 5 gallon bucket, and keeping the tractor as wet as possible, using rags and soft to medium scrub brushes spent 3 hours scrubbing it with soap solution till clean (what a mess!) After this was thoroughly dry, most of the paint was oxidised and dull. I have a polishing compound I mix myself made of pumice, light oil and a solvent that I use for removing blemishes and blush from the Laquer I spray in my shop. With that and another three hours using rags, soft brushes and a rubber pick to get crap out of corners and you have it.
My polish softens most finishes (they re-harden). Auto buffing compound doesn't, but tends to leave visible traces that really show up on black.
Edit: It was a lonnngg day start to finish, but I went through the hydro and put the shroud back together too. Since I decided to check EVERYTHING, I figured might as well clean it good first, and as usual, I got carried away. Just about to mount the mower deck and make some stripes! :)
2nd edit: It was dusk when I took most of these pictures (no accident) and I used a tripod and/or an auxillary flash to take these pictures, increasing the shine, and I only posted the best 8 out of 30 picture. :)
Gray Posted - 09/02/2010 : 13:31:12
Larry, did you just pressure wash? or use a degreaser? It almost looks like you painted the engine, etc.
I pressure washed mine back when I bought it; and was happy with the improvement also. But it doesn't look that good like yours. It's been well treated, or barely used. Certainly not bashed around much.
Myrple syrple = Maple Syrup - I guess that's an old Canadian tradition; but I guess it has spread to the States; probably well known in NE states, New England area. I guess there's some restaurants in NYC that feature it now (as if it's a new trend, it's old pioneer stuff). "Sugar maples" are the best species; there are oh approx 8 species of maples, mostly hardwoods, some soft woods. The have maple syrup festivals around here in the spring time, also big in Quebec. Heavy maple forest is called "sugarbush".
edit = I should add that maple syrup is not just a stupid sugar treat. It contains complex carbohydrates, plus vitamins, plus minerals. So it is actually real food.
(There's also a little known cleanser called the "master cleanser" which uses maple, lemon, cayenne (real ingredients only, no substitutions) in a specific exact mixture as a food support during a 10-day "fast". Read the book, if interested, before attempting).
Cvans Posted - 09/02/2010 : 10:39:03
Maybe Old Rover took a liking to that wheel. He wouldn't have to put his signature on it too many times to cause that rust. Nice looking machine. You could park in my yard anytime.
Chris
larry8200 Posted - 09/02/2010 : 05:16:45
Originally posted by Gray
Yah, looks like newish. Even the decals in front of the seat look like replacements. Did you oil or armorall everything? Too shiny. It must be closer to mid 80's year.
Strange that one wheel comes up rusty; maybe it's a replacement - none of the others look anything like that.
Can we have pancakes and myrple syrple tomorrow?
Only the drive belt is new, I said it had to have sat in the weeds, only way to explain the rust on the deck and wheels. the seat pan under the seat is also like that from holding water.
Pancakes are great, dont know this "myrple syrple" is it something Canadien?
Gray Posted - 09/01/2010 : 23:37:28
ATF Posted - 09/01/2010 : 20:38:17
Looks like you oiled it up like a pro body builder, he he. That is one clean machine. BTW, Larry I would highly recommend the skinny wheels and tires on this machine, it will sure make it steer easy. I used sealed bearing wheel barrow wheels with the short shaft and 3/4" hole, for tires I used diamond stud knobby's, but the little trailer tires make a good turf tread, the 4.80 AGs are nice also and cheap.
acb10_64 Posted - 09/01/2010 : 20:15:12
Looks great Larry! I wouldn't recommend cooking on it now that its cleaned up!
Saw a 7116 at the shop at my local Simplicity/ AGCO dealer today. It was having the BGB rebuilt. The main drive ball bearing had seized. Great looking machine, had a Briggs in it. It was good to see the owner was getting it fixed, you know what i mean.
Take care and keep the pics coming!
thepatriot Posted - 09/01/2010 : 20:03:39
What a looker!!!
