Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 8620 / Visits Today: 2970
Highest Active Users: 8620
 Rear Hitch Update
ATF Posted - 07/30/2010 : 08:01:22
All I have to do is drill five holes, the two hitch pin holes, two stabilizer bolt holes, and the clevis hole. Then I can weld it all together
skunkhome Posted - 08/14/2010 : 08:21:34
Originally posted by freddie
it would be better it he had the front counter wieght to make up the diff on the rake.
I think a shorter tongue would make it much easier to lift.
freddie Posted - 08/13/2010 : 13:52:01
skunkhome Posted - 08/11/2010 : 07:24:00
Originally posted by SCUMMY
Gday
this is what i made and it lifts better then i thought it would?
the rake is only good in loose stuff
cheers
Looks like that Simplicity has really had an impact on your place, Scummy. Good investment! I bet that rake is a bear to lift sticking out that far in the rear.
ATF Posted - 08/10/2010 : 19:04:18
Yeah, I couldn't get the back cup and seals and rod out, they weren't too bad though, it all works great now.
olcowhand Posted - 08/10/2010 : 18:47:37
I forgot the lift is operated by cable. My 416 didn't have rear lift, and the only Allis/Simplicity I've ever owned, so I stuck my foot in my7 mouth on that one. Some cylinders are tough to get the piston seals into the tube. Was that your issue?
ATF Posted - 08/10/2010 : 18:03:25
Thanks Daniel, I've heard that before, I hadn't even considered having down pressure on a sleeve hitch, since it's a cable lift, I don't even know how it would be possible. i was thinking of you the other day, when I was helping my buddy with his MF231, we were trying to put a new kit in the power steering cylinder, sure could have used your expertise, lol, just ended up doing half of it, but it works.
olcowhand Posted - 08/10/2010 : 15:49:35
Mike, I'd just use a chain for the lift. This will allow for float. Some want down pressure, but it's nearly useless on garden tractors, as it unloads the rear wheels & traction is lost. The main problem with your lift rod is that it has to bend in order to move, as the rod is rigid mounted and cannot change angle.
freddie Posted - 08/10/2010 : 15:38:39
this my sears that i use for draging the drivway
SCUMMY Posted - 08/10/2010 : 13:30:35
Gday
cheers
freddie Posted - 08/01/2010 : 18:52:32
ok i gotcha. thanks.
ATF Posted - 08/01/2010 : 15:25:16
i use mine the same way but i just use the origanal lift. for my tiller, cutavater.and rear plow. what is the advantge of this attactchment. just wondering.
You will need this style of rear hitch to use many of the attachments that are not OEM like rear scraper blades, box blades, or attachments made by Brinley,
Agway, etc... They will not attach to the OE< FDT sleeve hitch like is on your plow. I believe they are needed for the RBTs also.
Really I sure thought they would, older sleeve hitch is just short with no attachment bolts aren't they? This type of hitch allows you to turn with and use implements that need to be drug further back, maybe?
simplelife Posted - 08/01/2010 : 13:55:43
freddie Posted - 08/01/2010 : 12:40:17
freddie Posted - 08/01/2010 : 12:35:27
larry8200 Posted - 08/01/2010 : 12:25:45
I like it
This page was generated in 0.94 seconds. Snitz Forums 2000
