Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 5440 / Visits Today: 39
Highest Active Users: 5440
 Main drive belt 3416H yuk
larry8200 Posted - 07/02/2010 : 20:45:11
The original belt was getting decidedly frayed and fuzzy, and the idler had a good 1/8" play so.... It was time. Note that the bottom of the cowl is held on by the anchor bolt on the brake band, and the nut on the actuator rod had to be removed to get enough clearnce to get the anchor bolt out. Couldn't see that in the manual. The cowl has to come completely off to change the belt. Also note in first picture you can see the belt was tracking against the inside. This was done so they could hook the tension spring around the idler bolt and still put it together. They have a second nut on the end of the bolt to keep the spring from sliding off. They had a half inch, I put 2 washers with the idlers spacer and centered it up, leaving 1/4" for the spring
Quite a pile of crud underneath when I was done!
oldsarge Posted - 07/11/2010 : 18:34:03
[quote]Originally posted by ATF
Scary like photos of Rosie O'Donnel Nekkid
Try a movie called"Exit to Eden" ,not quite nekkid(bustiere' and long stockings)This was made up for by Dana Delany who was nekkid!!!
skunkhome Posted - 07/05/2010 : 13:57:07
One thing about a cream colored mower... you know when its clean, which BTW is almost never
AC716H Posted - 07/05/2010 : 06:07:38
I keep wondering why Simplicity painted the mower decks white. Probably some sadistic person made that decision. I think it's the worst color you could pick for something that drags across the ground and gets covered in dirt and grass.
ByronC Posted - 07/05/2010 : 04:29:37
Hmmmmmmmmm, Scary maintenance schedule you have.... lol :)
larry8200 Posted - 07/04/2010 : 11:57:10
I'm speechless, maybe go clean the toilet for an improvement...
skunkhome Posted - 07/03/2010 : 22:19:02
That conjures up a mental image that is unbearable.
ATF Posted - 07/03/2010 : 22:12:25
skunkhome Posted - 07/03/2010 : 20:23:44
larry, those pictures are kinda like the old VD scare photos or autopsy photos they publish to scare folks to stop smoking, drinking, overeating and make them start living a clean life. Now everyone with an old Vickers transmission is gong to go out and clean the heat exchanger.
ATF Posted - 07/02/2010 : 23:10:29
I'm going to take my cowls off and clean both my tractors tomorrow
skunkhome Posted - 07/02/2010 : 22:56:17
that transmission ought to breath well now.
This page was generated in 1.04 seconds. Snitz Forums 2000
