 SURGING SIMPLICITY, AC, HYDRO 712H
wtozzi Posted - 04/05/2008 : 18:15:58
I HAVE A ALLIS CHALMERS 712H, SAME AS SIMPLICITY 7012,7014,7016, ETC.
HAD A SURGE PROBLEM IN FORWARD , WOULD GO, PAUSE, GO, PAUSE, GO,.
AFTER CHANGING HOSES, FLUID,AND ALMOST CHANGING THE PUMP-DRIVE ASSY.
, NOTICED , WITH THE SEAT UP, AND PUTING IN FORWARD, THE WHOLE REAR END WAS MOVING.....COULD NOT UNDERSTAND HOW I MISSED WHAT I WAS SEEING, THE FOUR BOLTS THAT HOLD THE DIFFRENTAL TO THE GEAR BOX WERE ALL LOOSE.
TIGHTENED THEM ALL, (A OK)
wtozzi Posted - 04/06/2008 : 19:40:26
Originally posted by B112
Hello wtozzi- also glad to hear you fixed your problem. I presume your bolts being loose was effecting the pulley tension between the BGB and the rear pump. Sounds good.
No had nothing to do with the belt at all.
When the transmission rocked back because of the bolts loose, it changed the position of the lever on the pump.
B112 Posted - 04/05/2008 : 19:02:19
mikefox Posted - 04/05/2008 : 18:20:58
Glad you fix the problem.
I find your post difficult to read being all upper case.
This page was generated in 0.02 seconds. Snitz Forums 2000
