 Junky Craftsman rRepair
kma4444 Posted - 04/13/2009 : 19:21:02
Hey guys, sorry for the incomplete set of pics on this, I didn't think it was going to be so comprehensive until I was way into it.
Here's a link tot he photobucket album http://s526.photobucket.com/albums/cc341/kma4444/Craftsman%20mower/?start=0
And a teaser picture.
Anyway, it was a free thing from the father in law. Looked OK, just an old Craftsman with a non-running 15.5 Kohler. The deck was there but not installed. He thought it needed a valve job as it had a case of the backfires. I checked it out and after getting over looking at the valves moving oddly, internal automatic compression release, it bacame obvious it had a bad coil. I ordered it and a set of blades.
The steering on this was unbelievable, a plastic housing that the pinion ran in was completely worn out and there was about 1/2 a revolution before the wheel affected the tires at all. I just wanted to take that assembly out and repair it. Turns out, you pretty much have to disassemble the tractor to get it out so that was part of my reason for gutting it. The other was the frame was cracking in many places around the front axle. In the end, it came most of the way apart.
As for the color, I had it left over from a pickup I used to have, the black is just some Nason enamel with flattener in it to knock off the shine a bit. I fixed the steering by making bushings for the pinion support and the rack shaft. The front of the frame I plated with some .090" 4130 steel I had, I wouldn't have used it except it was all I had that was close. The deck was rusty so I cut out and replaced some of it. One of the blade bearing housings had an ear broken off and a bolt broken in it. I welded back the ear and hucked it in the mill to get the bolt out. That went pretty well except for the broken tap right at the end.
This thing had so many broken, cracked and just plain old worn out pieces that it certainly wasn't worth the effort, but I had too much time in it already. I'm pretty much done except for a seat and finishing the dash which, like much of the thing, was completely rusted. I tied up about 7 days pretty straight getting it this far.
Again sorry for the lack of pics, I feel sorta guilty as I have enjoyed other's posts on here. I'll do better if I ever take Ol' Blue down.
andrewk Posted - 08/27/2009 : 23:30:44
Nice paint job! One trick I use while spray painting outdoors is paint a piece of scrap about 5 minutes before you paint the work- Most, if not all the bugs will go to the scrap!
Andrew
terdybukrat Posted - 08/15/2009 : 16:47:27
Kevin, hows that pretty "Carolina blue" Allis with the loader coming along?
Terry in NC
B-16_IC Posted - 04/16/2009 : 12:34:07
I like the color! Almost makes a Crapsman attractive! The steering on those things is horrendous, if you get it working good it is a testimony to your skills. They do make a decent mower when they work proper, they don't respond well to abuse though as many people find out.
kma4444 Posted - 04/15/2009 : 07:20:38
Thanks all. I threw a seat on it and mowed my field and backyard yesterday, took a couple breaks for some small adjustments but it worked well. The steering still is awful, but it's a lot better than it was. Maybe at the end of the year, I'll pull the top half of it apart to get the steering system back out and fix it one more time. I think I have a handle on what will make it as good as possible now.
The Kohler ran great and it was a lot better than the 36"? cut old Snapper I've been using for the last 6 years.
Hey Roy, on the paint thing, the only bad thing I've found about being reasonably good at it is, you have to do it. If I was awful at it, I'd have to find someone else to do it for me, then I wouldn't have to. And the pics of course don't show the flaws, it's not too bad, just a sag on the right side of the hood and some natural inclusions from my spray booth, bugs. It seems the bugs really are attracted to yellow in the spring. I will have to wetsand and buff it out because it will aggrivate me every time I walk up to it. I can't believe I'm actually gonna buff on a lawnmower but there ya go.
Roy Posted - 04/14/2009 : 17:23:45
Looks great.
Wish I could paint that good.
SCUMMY Posted - 04/14/2009 : 12:57:23
gday
nar that looks ok mine might look as clean as that 1 day
so long as u happy with it thats all that matters
cheers
kma4444 Posted - 04/14/2009 : 09:37:55
Yeah, the thing isn't much of a tractor, fair enough to call it a riding mower. It's sprayed on, and the yellow is basecoat clearcoat, not because that's what I wanted to do, it's just what I had on hand.
Here's a pic of it ,ostly done for those who don't want to go around looking for pics of a sad little riding mower.
B112 Posted - 04/14/2009 : 06:56:27
Looking Good there Kevin. I like seeing all machines getting maintained and saving us all work. Did you spray that paint on or brush it?
skunkhome Posted - 04/13/2009 : 22:17:41
That is quite alright... one picture of a Crapsman is plenty. Just kidding. Let us know how your final product turns out.
This page was generated in 0.02 seconds. Snitz Forums 2000
