 Working on Kubota G5200HST
skunkhome Posted - 09/15/2008 : 00:03:27
I changed the Hydrostatic transmission oil filter today. I had to pull the right rear tire off to do so, so I adjusted the brake free travel as well. The brake action is much bertter but for the life of me I can't see the brake at all. I think it is a disc between the hydrostatic motor and the trans axle. Can't figure how to get to it to do service. I have a parts manual coming though and it should give me some insight. I checked the transmission oil and thought it was down so much it would not touch the dip stick but when I set out to fill to proper level I over ran the top of the fill hold. The dang dip stick is very hard to read with the near crystal clear oil, and apparently the oil level was fine before I started to refill. I had to siphon the oil back down to the proper level. What a pain. Also tried to service the front wheel bearings but found that they could not be tightened up as there is a shoulder which goes from 3/4" to 1" shaft where the bearings ride and the jamb nut and 3/4" washer were tight down against the shoulder on both spindles. Looks like I need to get one or two 1" ID washers to use as spacers to take the end play out of the bearings. in addition to the tractor parts manual I won a tractor and mower operators manual on ebay today. I am also bidding on a mower parts manual. I should have plenty of reference materials in short order.
12   L A T E S T    R E P L I E S    (Newest First)
simplelife Posted - 12/23/2008 : 07:19:11
I guess I just need to start taking things apart and see where it takes me.
ZippoVarga Posted - 12/23/2008 : 00:22:35
I wouldn't grease the spline shaft that the brake disc rides on. The grease will sling onto the brake disc and really cobble things up. Then you'll HAVE to tear it down to get it degreased. I suggest a couple rubber bushings to quiet things down. One on either side. Also, if you're feeling ambitious and do tear it down, a little anti squeal behind the pads will help some of the chatter also. IMHO of course.
haykarenhardy Posted - 10/20/2008 : 19:28:42
Now is the time to mount your deep deck and rear lift. Looks like you have a good hydro unit and engine.
Stan
skunkhome Posted - 10/19/2008 : 21:24:42
Well, you have an Eaton model 11 hydrostat unit. Same as on my Unico 15 made by MTD. Many makes use the Eaton 11. Good hydro's.
I am really pleased with the transmission and engine. Mower is giving me grief though. I think the key now is the front links which I believe are too long allowing the front of the mower to dig even in the raised position. I don't know what length they need to be. It would be helpful to get that length "A" from pin to pin as one of the turnbuckles is welded on one end so it can't be adjusted in place.
olcowhand Posted - 10/19/2008 : 21:12:30
skunkhome Posted - 10/19/2008 : 20:56:53
I finally took the rear shroud off my Kubota today Just to look around. I must say that I know little more than I did before.
The channel iron frame was full of caked on mud and grease so it was pretty hard to see much of anything.
I was particularly interested in the brake disc which rattles like crazy (green arrow). It floats on a spline shaft and is held in place by a "C" clip. It wanders back and forth on the shaft until the brakes are applied. It is pretty noisy but I can't figure how to get to it without doing a lot more dismantling of the tractor. Maybe a coating of heavy grease on the shaft would stop the rattling.
A little clean up allow me to see a better and discovered some rust through on the bottom rail of the frame.
Even with years of debris removed I am still unable to tell much about the disc brake. My manuals aren't much help either. I guess I just need to start taking things apart and see where it takes me.
olcowhand Posted - 09/18/2008 : 09:02:05
That's a lot of free play! Bearings worn that much? Even if they are worn, tapered have a lot of room to keep tightening up when it's not going at highway speeds. How you like the power of that diesel? I absolutely LOVE mine!
Daniel, if the hour meter isn't bogus (960 hrs)there is no way I would have that much wear. I think some spacers are missing. hopefully my parts manual (on the way ) will shed some light. Even at 14 Hp that 3 cyl diesel is a beast. So much torque! It will actually snap your head back if you slap the throttle forward.
That's a huge coincidence...my MF1010 had EXACTLY 960 hours on it's clock too!!!
skunkhome Posted - 09/17/2008 : 23:23:46
olcowhand Posted - 09/17/2008 : 09:06:04
skunkhome Posted - 09/16/2008 : 23:06:45
[quote]Originally posted by olcowhand
I've bought shims to tighten bearings like you describe. Ask for shim washers, as they have narrow widths.
Well, I don't think I need them too narrow as I have about 3/16" end play...BTW, just won Kubota parts manual minutes ago.
skunkhome Posted - 09/16/2008 : 23:04:44
olcowhand Posted - 09/15/2008 : 09:48:46
I bought an IT shop manual off ebay Saturday for my MF1010. Always good to have a manual. Mostly I don't use a manual, but when it comes to remembering all the torque values & clearances, there's NO way I can remember all that stuff.
BTW...you're not alone in overfilling, done that before too! I've bought shims to tighten bearings like you describe. Ask for shim washers, as they have narrow widths.
