Author |
Topic ![Next Topic Next Topic](icon_go_right.gif) |
5241 Posts |
Posted - 03/05/2007 : 18:52:02
This chapter lists the B-Series engines used from 1957-1970. (It's under construction with a few notes. Future pictures...) Focus will be on common issues on the B-Series, you must review the links at the bottom of this page.
7.25hp Model 19 used in the 700 and 725 series
![](http://www.michaelstractors.com/forum/upload/B112/2007316185938_19D.jpg)
Points: 292021 Condensor: 291369
![](http://www.michaelstractors.com/forum/upload/B112/2007112617365_Points23D19.jpg)
Operating and Mainenance Manual: /B112/Model19-Domestic.pdf (No parts catalog)
Note: I incorrectly had the Model 19D Type 706047 listed here before, that was an error.
9hp 23D used in the 64 Landlord & Early B10. It is considered an antique. http://www.asecc.com/data/briggs/data4.html#23D
Operating and Mainenance Manual: /B112/Model23-Domestic.pdf (with parts catalog)
Uses a Type Q carburator called a "large Flo-Jet two piece".
10hp: Used in the Landlord 101,Landlord,2010,2110 and the BigTen,Late B10,B110,B210 243341
![](http://www.michaelstractors.com/forum/upload/B112/2007316185957_243431.jpg)
12hp Used in the 2012, 2112, B12, B112, B212 300421 Briggs and Stratton 12 HP http://shop.briggsandstratton.com/BShopProductPage.asp?CatalogID=656F8AC4-B611-4BB3-95BF-A9C915B1275A&MECID=100&CategoryID=&lrid=&ProductID=56B2BC12-283C-11D4-8886-00B0D0203414#
Some common parts: Welch Plug for briggs 300421 0127A - 12hp Briggs #690627 also 221747 See http://www.mfgsupply.com/22-7971.html Part #: 22-7971 selling at $0.98
Air Filter - Briggs #270093 Condensor 298060 Points 298185 Spring Breaker Arm 26018 Spark Plug 221798 (superceed: 492167S) Champion CJ8 Briggs & Stratton J19LM Spark Plug
See briggs links and charts below: http://www4.briggsandstratton.com/display/Router.asp?DocID=75583&spTYPE=12 http://www4.briggsandstratton.com/miscpdfs/sparkplugDefinitions.pdf
14 mm Heads Gap to 0.03 B&S PN:492167 Champion PN: J19LM Long Life PN: 5062
Standard Plug CJ–8 298809 Standard Plug J–19LM 492167S Resistor Plug RJ–19LM 802592S Resistor Plug RC–12YC 491055S Resistor Plug RC–14YC 496018S
http://www.peco-ca.com/catalogs/genuine_parts_catalog.pdf
![](http://www.michaelstractors.com/forum/upload/B112/200731619019_300401.jpg)
Engine Rotation: Front PTO side turns counterclockwise Flywheel/driveshaft side turns clockwise
Must Review Links This site maintains a manual for engine maintenance: http://www.repairfaq.org/sam/lmfaq.htm
Click on the manual below for the Online Briggs and Straton Service and Repair Instructions Manual:
![](http://www.michaelstractors.com/forum/upload/Homesteader/2007112793923_BSmanual.jpg)
Some other articles to review:
New Posts Cast iron Briggs - points
