 B-Series 42" and 48" Decks, differences and links
Posted - 03/05/2007 :  18:21:06  Show Profile  Visit B112's Homepage Send B112 a Private Message
Overview:
This post is trying to gather all information about the 42" and 48" B-Series and appropriate Simplicity Lawn decks. I'll be photographing decks I have and searching the forums to assist in getting as much information available. I'll be posting questions in the discussion forums to see if others can assist in detailing this tip.
48" deck roller bar length:
46 1/4" - 46 1/2" by 5/8" diameter uses bushing (part # 2108419)
has cotter pin holes are 3/16" dia.
Note: Can use 5/8" shaft collars verses cotter pins from TSC or Big R.
Sketches & Pictures of the various 42" Decks:
42" Rotary Lawn Mower 1690252
3112H,3112V,3012,2012,B12, - Requires 103232, 103220, 108248
2110,2010,Landlord - Requires 103220, 103232,103253,108099,108794
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_100_2978_02_AT_S.pdf
42" Rotary Lawn Mower 1690022
3112H,3112V,3012,2012,B12, - Requires Hitch 1690082, Kit No. 103220, 103232 & 108248
2110,2010,Landlord - Requires 103220, 103232, 103253,108099,108794
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_100_2872_00_BM_S.pdf
42" Rotary Lawn Mower 990885
3112H,3112V,3012,2012,B12, - Requires Hitch 103220, 103232 & 108248
2110,2010,Landlord - Requires Kit No. 103220, 103232,103253, 108099 & 108794
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_400_1362_00_AT_S.pdf
42" Rotary Lawn Mower 990784
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_400_1354_00_XX_S.pdf
42" Rotary Lawn Mower 990670
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_400_1334_00_AT_S.pdf
42" Rotary Lawn Mower 990575
3112H,3112V,3012,2012,B12, - Requires 108207, 108248, 103220
2110,2010,Landlord351,Landlord270,725,700 - Requires 108207, 108099, 103220
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_400_1322_00_AT_S.pdf
42" Rotary Lawn Mower 990544
3112H,3112V,3012,2012,B12, - Requires 170011, 103220, 108200
2110,2010,Landlord351,Landlord270,725,700 - Requires 108099 Belt
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_400_1313_00_AT_S.pdf
(See 990501 below for photo.)
42" Rotary Lawn Mower 990501
3112H,3112V,3012 - Requires 108248
2012,B12,2110,2010,Landlord351,Landlord270,725,700
42" Rotary Lawn Mower 990407
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_400_1280_00_AT_S.pdf
42" Rotary Lawn Mower 990190
Intended for the Model 725 (will get a better real picture)
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_400_1236_00_AT_S.pdf
Key Differences between the various 42" decks:
Difference between the 990407 and the 501,544 and 575 42" rotory mowers
Notice that the Bail Assembly has a solid bar after the 407 model. They must have discovered that was a weak point. So that's how you can tell you have the 407.
Differences between the 990501 and the 544 & 575 42" rotory mowers:
The 501, 544 and 575 all look to be exactly the same part numbers by comparing two manuals. The 501 & 544 only have one manual and the 575 has it's own manual. After comparing each of the diagrams, I'm fairly confident these manuals only differ by page 3 and page 8. So if you have one of these decks without the sticker, they are the same.
#1 - Page 3 of the 545 manual has a diagram of the adapter kit shown here:
#2 - Page 8 of the 501 & 544 manual lists the AM part which is not listed in the 545 manual:
Sketches & Pictures of the various 48" decks:
(work in progress this section)
48" Rotary Lawn Mower 1690021
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_400_0221_00_BR_S.pdf
48" Rotary Lawn Mower 990669 (Note Production year 1971)
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_400_1333_00_AT_S.pdf
48" Deck (need to identify the MFG#)
Key Differences between the various 48" decks:
Notice that the 1690021 has only three rollers in the middle of the roller attachment verses the 990669 has four rollers. The 1690021 seems to side from side to side.
Key Differences between the various 42" and 48" decks:
This section will attempt to show what parts can be switched between the various 42" decks and the 48" decks.
Note: The roller bar on the 48" deck has a slight curve to the mount on both the 1690021 and the 990669. Will show measurements, pictures and sketch of this difference.
Deck height adjustment:
42" Lawn Deck 990285:
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_200_3620_00_XX_S.pdf
Simplicity 42" Replacement Blades:
Simplicity Part Number 108298 Knife Blade
Stens replacement blade design specifications:
* Requires 3 for 42" cut
* Length: LH 14 9/16"
* Center hole: 1 3/8"
* Outer holes: 25/64"
* Center/Center: 3 1/16"
* Straight blade
* Width: 2 1/2"
* Thickness: .150"
