Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 11854 / Visits Today: 6522
Highest Active Users: 11854
 WD-45
SimplicitySwede
Posted - 08/04/2013 :  21:28:14  Show Profile  Visit SimplicitySwede's Homepage Send SimplicitySwede a Private Message  Reply with Quote
So I have kinda started my own business I think. I been working on a Farmall H that I have been restoring for a guy. Well my dad works with a guy who wanted his WD-45 painted. He told me its been sitting in a shed for bout 8 years. I told him I could do it. Which included I had to get it running. Well he winched it on a trailer and dropped it off at my house. Well My buddy and I were looking at it. Im a Farmall guy and know nothing about AC. I asked him if he wanted to try and get it running? hes like sure. I said 1st things 1st. Grabbed the hand crank and went to turn it over. Wouldnt budge. Great. Pulled the plugs corrosion on number 2. Shined a light in the plug hole and saw rust. Yup shes stuck solid. I called the guy and he said he wanted to overhaul it. So thats what ill be doin. I may have a few ?s for you guys here. 1st off whats the best way to pull an engine outta a 45? Heres some pics
http://s1172.photobucket.com/user/SimplicitySwede/library/Toys/Allis%20Chalmers%20WD45%202nd%20Customer%20Dan%20Carson?sort=3&page=1
Posted - 08/04/2013 :  21:57:53  Show Profile Send skunkhome a Private Message  Reply with Quote
I thought they used to do the overhauls in frame. I believe the cylinders have wet sleeves. I think they are still available if honing won't correct.
Posted - 08/04/2013 :  22:10:06  Show Profile Send Cvans a Private Message  Reply with Quote
I'm with Phil, just do it in the tractor. If you have to pull the engine I think you can do it without splitting the tractor as it has a full length frame..
I had two WC's but never had an engine problem. Somewhere around here I still have a factory service manual for Allis tractors but I'll have to see if yours is in there.
Posted - 08/04/2013 :  22:19:31  Show Profile Send skunkhome a Private Message  Reply with Quote
Check the internet. You should be able to find complete kits for in frame overhaul.
SimplicitySwede
Posted - 08/05/2013 :  03:08:35  Show Profile  Visit SimplicitySwede's Homepage Send SimplicitySwede a Private Message  Reply with Quote
I haven't checked the crank yet. That will be the deciding factor. But new sleeves is a must. I figured it was dry sleeve tho
Posted - 08/05/2013 :  07:04:59  Show Profile Send skunkhome a Private Message  Reply with Quote
Are those flat top pistons? I thought the WD45 had power crater pistons. I wonder if it was rebuilt with WC pistons to boost hp.
Edited by - skunkhome on 08/05/2013 07:05:27
Denny
Posted - 08/05/2013 :  08:33:55  Show Profile  Visit Denny's Homepage Send Denny a Private Message  Reply with Quote
Definitely do it in the frame,,, we overhauled a 45 once,,, out in the field ,,, cracked the head, seized one piston,,, 6 hours later, up and disking again.
Early B10
67 Bee10
68 B16HD 112 Loader
68 B112 L112
68 B112
4041 Power Max
Posted - 08/05/2013 :  09:12:02  Show Profile Send Cvans a Private Message  Reply with Quote
Now you know for sure it can be done. This would save you a lot of time if the crankshaft seals are good.
SimplicitySwede
Posted - 08/05/2013 :  13:08:46  Show Profile  Visit SimplicitySwede's Homepage Send SimplicitySwede a Private Message  Reply with Quote
This tractor I think is 2 tractors in one. It has WD45 features but also has a few WD features. I think the engine is a WD. One thing I See though is. The outta frame kit is not much more than the in frame kit. In a way I think the best thing to do it all. Then I know everything was done to it. Ill decide when I get the pan pulled off the bottom of it, then Ill know what to do.
Posted - 08/09/2013 :  07:19:42  Show Profile Send skunkhome a Private Message  Reply with Quote
Well if the stroke is 4" the engine is from a WD or WC. If its 4.5" is WD45 or even D17. D17 has larger journals and mains.
SimplicitySwede
Posted - 08/10/2013 :  15:57:51  Show Profile  Visit SimplicitySwede's Homepage Send SimplicitySwede a Private Message  Reply with Quote
The difference I noticed is the WD has a plate bolted to the side of the block for lifters. The 45 doesnt. Im amazed by the ratio of weight to HP to theses things. The need to weigh a little more in my book.
