 1693497 - 36" Tiller Adapter Kit (984263)
Posted - 03/05/2007 :  19:07:41  Show Profile  Visit B112's Homepage Send B112 a Private Message
As I recall if you get every part new, it will cost about $175. It's very likely when you try to get one of these, someone will sell it as high as $150. Silly, but everyone sells tillers without the pulleys. Generally easy to find a tiller for $50-100... get everything you need... that's another story.
36" Tiller Adaptor Kit (984263)
1 1917372 NUT-HEX, 5/16-18
2 1917356 LOCKWASHER,5/16
3 105359 SUPPORT, Rear Belt Guard
4 1707593 SPRING, Torsion
5 1707599 ANCHOR, Spring
6 105346 SPACER
7 1704716 SPACER
8 1923141 CAPSCREW, Hex Head, 5/16-18 x 2-3/4
9 960171 WASHER, Nylon
10 1666106 BUSHING
11 1919326 WASHER
12 176012 RETAINER PIN
13 1707564 COVER, Belt
14 1657562 ROD
15 1669999 SPACER
16 1708352 GUARD, Spring
17 157427 KEY
18 1960474 SCREW,Set Square Head, Cup Point, 3/8-16 x 1/2, G8
19 1706342 PULLEY, 9inch OD
20 1721133 PULLEY, Idler, 2-3/4 OD
21 1706511 PULLEY, Idler, 1-7/8 OD
22 1924940 WASHER
23 1921971 CAPSCREW,Hex Head, 3/8-16 x 1-3/4
24 1920415 CAPSCREWHex Head, 3/8-16 x 1-1/4
25 1916965 LOCKWASHER, 3/8
26 1706510 PULLEY, Idler, 4 OD
27 1707265 ANCHOR, Jackshaft
28 1706512 V-BELT
29 1708961 SHAFT & SUPPORT ASSEMBLY
30 1960251 NUT, Hex Center Lock Jam, 3/8-16
31 1921210 CAPSCREW, Hex Head, 3/8-16 x 1
32 1960116 PIN, Yoke, Drilled
33 1960033 CLIP, Hair Pin
34 1706344 CLEVIS & BAR ASSEMBLY, Anchor
35 1921333 CAPSCREW, Hex Head, 5/16-18 x 1
36 1706362 PULLEY & SHAFT ASSEMBLY
37 1960160 WASHER
38 1611789 SEAL, Oil
39 171186 BEARING
40 912808 FITTING, LUBE
41 * CLEVIS ASSEMBLY, (See Ref No. 42) * See Refrence No. 42 for parts.
42 1708180 CLEVIS & HOUSING ASSEMBLY, w/ Bearings (Includes Ref. Nos. 39 & 40)
43 159159 SPRING, Extension
44 1916950 NUT, Hex, 3/8-16
45 1706508 ARM & HUB ASSEMBLY
46 1657712 PULLEY, Idler, 3-5/8 OD
47 1700059 V-BELT
48 1923701 CAPSCREW, Hex Head, 3/8-16 x 2
49 960403 KEY, WOODRUFF, #61
50 1928721 SCREW, Set, Square Head Cup Point, 5/16-18 x 1/2, G8
51 1706343 PULLEY & HUB ASSEMBLY
52 1708298 PIN, Round Head, Drilled
53 1923362 NUT, Hex Centerlock, 5/16-18
