 JD 430 Diesel
Previous Page
Posted - 10/08/2012 :  10:36:08  Show Profile Send Cvans a Private Message  Reply with Quote
Not having another tractor with a loader does make moving a dead Kubota a problem. One of the shortcomings that should have been corrected during the design phase.
Posted - 10/08/2012 :  11:06:22  Show Profile  Visit olcowhand's Homepage Send olcowhand a Private Message  Reply with Quote
I was wrong about deck wheel settings. They are to be 1/4" from a flat surface with the travel limiter set for that height. They ARE for anti-scalp/anti-dig! I set them correctly, then mowed a spot. Mowed even nicer than yesterday,& no divets this time. The back of the deck was way higher than the front yesterday.
Posted - 10/08/2012 :  11:33:22  Show Profile  Visit olcowhand's Homepage Send olcowhand a Private Message  Reply with Quote
That's the thing with my Bota....she always starts! Only one time did I ever have a problem, and it was in my drive, already out of the shed. She started stumbling, then died. Was just a clogged fuel filter, and an easy fix.
Posted - 10/08/2012 :  12:30:44  Show Profile Send skunkhome a Private Message  Reply with Quote
I don't know about later models but the G1800 also had no provision for free wheeling.
Posted - 10/08/2012 :  12:52:00  Show Profile  Visit olcowhand's Homepage Send olcowhand a Private Message  Reply with Quote
I have no idea as to whether the G4200 does or not. Never needed to know.
Posted - 10/08/2012 :  15:36:48  Show Profile Send Cvans a Private Message  Reply with Quote
I think the only time I've had to think about it is when I forgot to put fuel in it. If you shut it down right away it will start right up again when the fuel is added. I did a dumby once and tried to nurse it back to the shed. That time I had to purge air out of everything.
To the best of my recollection there is no free wheel provisions on these tractors. I could see where that could be a hassle.
Posted - 10/08/2012 :  15:43:22  Show Profile  Visit olcowhand's Homepage Send olcowhand a Private Message  Reply with Quote
I've ran my JD F935 out of fuel ONCE. Once is all it takes to never let it happen again! Liked to never have gotten it bled to fire!
Posted - 10/08/2012 :  18:29:33  Show Profile Send skunkhome a Private Message  Reply with Quote
The only issues I had with either tractors was with the batteries and I am not sure the glow plugs worked on my g1800. Cold weather starts were a bear but if I ran a hair dryer in the air intake to preheat the air it cranked up pretty easy.
Posted - 10/08/2012 :  18:47:02  Show Profile  Visit olcowhand's Homepage Send olcowhand a Private Message  Reply with Quote
Cold weather is Baton Rouge??? Your glow plugs must not have been working, as they do fine here unless it gets below freezing. My Kubota will start better than my other diesels in cold weather. My MF1010 has working glow plugs, but below freezing still requires plugging in the block heater. It's the coldest natured one of them all.
Posted - 10/08/2012 :  18:57:17  Show Profile Send skunkhome a Private Message  Reply with Quote
Posted - 10/08/2012 :  19:00:36  Show Profile  Visit olcowhand's Homepage Send olcowhand a Private Message  Reply with Quote
I got that the 1st time Phil!
Posted - 10/08/2012 :  22:38:41  Show Profile Send Cvans a Private Message  Reply with Quote
What are you talking about Daniel. I didn't hear an echo echo echo .......
Posted - 10/09/2012 :  08:05:02  Show Profile Send skunkhome a Private Message  Reply with Quote
darn iPad!
Posted - 10/09/2012 :  08:09:12  Show Profile Send skunkhome a Private Message  Reply with Quote
I had no difficult with the G5200 with its manually activated glow plugs but the g1800 went thru the starter switch which may have been defective. In fact as I recall I had to install a manual shutoff for the same reason.
Previous Page
