Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 6985 / Visits Today: 6870
Highest Active Users: 6985
 ground crew for this winter.
Tclark
Posted - 11/22/2011 :  18:00:59  Show Profile  Visit Tclark's Homepage Send Tclark a Private Message  Reply with Quote
this is my cleanup crew this winter. i have to get a belt and make a lift rod for the blower but the wd is all ready except for the chains they are somewhere in the shed. i also have a 27" walk-behind snow cheif snowblower
K1dan
Posted - 11/22/2011 :  18:22:59  Show Profile  Visit K1dan's Homepage Send K1dan a Private Message  Reply with Quote
If that doesn't get it done. It's time to move South.
Posted - 11/22/2011 :  18:33:20  Show Profile  Visit larry8200's Homepage Send larry8200 a Private Message  Reply with Quote
Yup, that will work!
Posted - 11/22/2011 :  18:54:37  Show Profile Send Cvans a Private Message  Reply with Quote
Hi Tyler. Good looking crew!
I have some photos for you
I actually made this lift rod from one I had off of another simplicity tractor. It is set at 29.5 inches from hole to hole on center.
Both filters get changed tomorrow.
Posted - 11/22/2011 :  19:13:05  Show Profile  Visit B-16_IC's Homepage Send B-16_IC a Private Message  Reply with Quote
I'd say you are just about ready! Be sure to stock up on hot chocolate supplys to get a little warm in the belly before heading into the cold. Should be pretty toasty though behind the heathouser on the the WD.
Tclark
Posted - 11/22/2011 :  19:18:47  Show Profile  Visit Tclark's Homepage Send Tclark a Private Message  Reply with Quote
thanks for the pics chris. now just to biuld it. what motor do you have in that one is it the 17 hp kohler? kinda looks like my onan
Posted - 11/22/2011 :  20:00:05  Show Profile Send Cvans a Private Message  Reply with Quote
The engine had been replaced with a Kohler 18hp magnum. Uses a very little oil and seems to always start in South Dakota
Need to get the oil and filters changed especially on the hydro. It is starting to slow down and I thought I had changed it. NOT!
ducky
Posted - 11/23/2011 :  10:27:38  Show Profile  Visit ducky's Homepage Send ducky a Private Message  Reply with Quote
Is that a 3 point hitch on the WD?
Ducky
Freedom, WI
Tclark
Posted - 11/24/2011 :  11:45:51  Show Profile  Visit Tclark's Homepage Send Tclark a Private Message  Reply with Quote
yes it is good eye even from behind the 916
