 what trans oil in a bolens duratrac?
superbinder
Posted - 04/11/2011 :  15:00:25  Show Profile Send superbinder a Private Message  Reply with Quote
I am running hyd. oil in my 2 speed transaxle, but when cold it won't go til it warms up 5 minutes or so.Would ATF work better?
BRAD1975
Posted - 04/11/2011 :  18:48:12  Show Profile  Visit BRAD1975's Homepage Send BRAD1975 a Private Message  Reply with Quote
Id say atf or even better a synthetic atf...I use the synthetic stuff in my western plow with no problems at all even when its super cold out
unless its calls for hypoid..then you need to get a lighter grade but make sure its hypoid if it calls for that
Im not sure what the duratrac is but my bolens hydrostatic has regular atf and works fine
Edited by - BRAD1975 on 04/11/2011 18:50:53
Posted - 04/11/2011 :  23:24:24  Show Profile Send Cvans a Private Message  Reply with Quote
My DuraTrac does the same thing except it is the power steering and power lift that I wait for. It moves OK but you can hear the relief valve opening until the Hydro warms up.
Edited by - Cvans on 04/11/2011 23:26:12
superbinder
Posted - 04/12/2011 :  01:32:07  Show Profile Send superbinder a Private Message  Reply with Quote
Yes you are right about the ps and lift.You just don't want to go anywhere till it will steer
Posted - 04/12/2011 :  09:13:20  Show Profile Send Cvans a Private Message  Reply with Quote
I've notice that since it has warmed up it is much better about coming out of the barn. Might have to try ATF after I get
the loader installed.
