Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 594 / Visits Today: 594
Highest Active Users: 594
 Front AG's are on the 7790!!!
thepatriot
Posted - 09/08/2010 :  17:28:14  Show Profile  Visit thepatriot's Homepage Send thepatriot a Private Message  Reply with Quote
We just finished up the grease job and wheel install.No rubbing and it turns much better too.I'll start the rears tomorrow.Here's a few pics of the tractor and my helper .
AC B10-Simplicity LL101,7010,7110,7790DIESEL
Edited by - thepatriot on 09/08/2010 17:29:05
Posted - 09/08/2010 :  18:05:19  Show Profile  Visit 1014211's Homepage Send 1014211 a Private Message  Reply with Quote
Cute helper. I like those wide AG tires on the front, I have skinny AG tires on my 2110.
Posted - 09/08/2010 :  18:07:09  Show Profile  Visit snohiker's Homepage Send snohiker a Private Message  Reply with Quote
hey i had a helper like that know she jumps in her car and runs when i need help enjoy while u can dude they grow up over night
Posted - 09/08/2010 :  18:15:37  Show Profile  Visit ATF's Homepage Send ATF a Private Message  Reply with Quote
What size are you using on the rear? and what size are the fronts?
thepatriot
Posted - 09/08/2010 :  18:43:41  Show Profile  Visit thepatriot's Homepage Send thepatriot a Private Message  Reply with Quote
The fronts are GoodYears in the stock size.I bought some Hi-Runs from TSC in 23x10.50 for the rear.They are a twin to Carlisle Super Lugs.
Edited by - thepatriot on 09/09/2010 09:35:31
Posted - 09/08/2010 :  19:53:06  Show Profile  Visit ATF's Homepage Send ATF a Private Message  Reply with Quote
I'm really not a fan of the 23x10.50-12. I think they look wrong, you don't see tractors running extra wide bar lug/flotation tires, they're taller and thinner, so they actually work.
thepatriot
Posted - 09/08/2010 :  20:01:55  Show Profile  Visit thepatriot's Homepage Send thepatriot a Private Message  Reply with Quote
These tractor's look good with the wide rear tires.The round hoods on the other hand look better with the skinny ones.
Posted - 09/08/2010 :  21:07:09  Show Profile  Visit acb10_64's Homepage Send acb10_64 a Private Message  Reply with Quote
Tires look great! Good help is hard to find these days, enjoy it while ya can!
Posted - 09/08/2010 :  22:25:15  Show Profile  Visit ATF's Homepage Send ATF a Private Message  Reply with Quote
It;s not so much the width as the height, I'll post pics of some 26x12-12, they look ten times better than 23x10.50's, even the 24x12's are better. The Massey has 26x12-12's and the Ariens has 23x10.50-12's. I just think the taller wide tires better than the shorter, if your going 23 height, I like 8.50 width. Doesn't really matter if your not running a 10 inch rims, the 8.50's once mounted on 8 inch wide rims will be less than a inch narrower than the 10.50's, look more balanced, and be a heck of lot cheaper, but your mileage may vary
Edited by - ATF on 09/08/2010 22:35:10
thepatriot
Posted - 09/09/2010 :  06:05:39  Show Profile  Visit thepatriot's Homepage Send thepatriot a Private Message  Reply with Quote
The taller tire also will raise your gear ratio.More speed=less torque.
Posted - 09/09/2010 :  07:47:51  Show Profile  Visit ATF's Homepage Send ATF a Private Message  Reply with Quote
It might at that, but the difference is insignificant, in comparison to the better traction A wide tire tends to float whereas a skinnier tire tends to dig in, ask a farmer. The 23x10.50-12 and the 16x6.50-8 are wide high flotation turf tires, when you translate it to a AG tire you get a wide high flotation AG tire, While it may look good in the same way those new low profile tires look on ma brothas Escalade, they aren't very functional. I'm not saying there's anything wrong with that, just saying if you think your going to plow with these and do as good as narrow front tri-ribs and 8.50's or 26 inch tall tires you might be mistaken. Besides the 8.50's aren't any taller. My point is not to dissuade you from using what you want, just to inform you that these tires will have more to do with looks than with performance in the field.
Finally, I'll tell you that 23x10.50-12's look GREAT on some tractors, not so much on others, has to do with the size and shape of the tractor. My Ariens is a big tractor, they don't look so hot on it, almost like those little fat tires that stuck way out the Latinos used on their Honda's a few years back. I actually think they would look good on the Allis/Simplicity machines, because they are a smaller tractor in dimension, they dont look good on a Cub Cadet 782 either, again a large tractor.
thepatriot
Posted - 09/09/2010 :  10:09:47  Show Profile  Visit thepatriot's Homepage Send thepatriot a Private Message  Reply with Quote
I also don't like the "raked" look.At least not on a tractor.
Posted - 09/09/2010 :  10:40:09  Show Profile  Visit ATF's Homepage Send ATF a Private Message  Reply with Quote
Whats the "raked" look
Posted - 09/09/2010 :  10:46:25  Show Profile  Visit freddie's Homepage Send freddie a Private Message  Reply with Quote
were the front is lower then the back, not level.
thepatriot
Posted - 09/09/2010 :  13:26:22  Show Profile  Visit thepatriot's Homepage Send thepatriot a Private Message  Reply with Quote
Looks good on a hot rod,not a tractor
Posted - 09/09/2010 :  15:35:55  Show Profile  Visit ATF's Homepage Send ATF a Private Message  Reply with Quote
I hope nobody's taking me the wrong way, I also like the looks of the wide AG tires, it's just that they really aren't very functional, mainly for show, and that's okay too
This page was generated in 1.4 seconds. Snitz Forums 2000
