 Index
Author Previous Topic Topic
Posted - 03/01/2007 :  12:04:17  Show Profile  Visit B112's Homepage Send B112 a Private Message
Classic B-Series & Simplicity Restoration Book
Index
This forum is the contents of the "Classic B-Series & Simplicity Restoration Book". This book is currently in draft and is copyright 2006-7 to this site and credits will be provided in the final appendix. Below you will find all the articles which make up the sections/chapters of this book. This is a work in progress! That means, things are changing and will change.
Acknowledgements:
1. Brief History - draft
2. Selecting a project Tractor - draft
3. planning your restoration -
4. Identification plates and documentation - WIP
5. Getting Started
6. Disassembly
7. Brakes & Steering & Tires - WIP
8. Frame
9. Engine Repair - WIP
10a. BGB Repair - Draft
10b. Differencial Repair - Draft
11. Transmission Repair
a. Manual Transmissions - under-construction
b. Hydrostatic Transmissions - under-construction
12. Fuel System - WIP
13. Electical Systems - WIP
14. Body Prep and Paint - WIP
15. Assembly - WIP
16. Attachment Adjustment and Maintenance
a) PTO Maintenance - Draft
b) Rotary Lawn Mower Repair and Maintenance tips -
c) Sicklebar
17. After the restoration. - WIP
Appendix
A - Recommended Vendors for Restorations - draft
B - Paint Guide - draft
C - Attachments and Options Reference - draft
D - Briggs & Stratton Engine Troubleshooting - under-construction
E - Tractor Reference Guide - WIP
F - Suggested Used Tractor/Attachment Price guide - draft
G - Parts Supplier Notes -WIP
Each document is marked with a status as follows:
final
These documents should be in their final form.
draft
These documents are draft and feedback would be appreciated at this point. If you see something which needs correction or updates, please post a suggestion in the Suggestions forum.
WIP
These documents are currently in a "Work in Progress" (i.e. WIP) form. They might be really rough. Please contact B112 if you have anything to add to these.
