 990370 - Weed Cutter
Posted - 08/01/2007 :  20:00:36  Show Profile  Visit B112's Homepage Send B112 a Private Message
Simplicity Manuals:
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_100_1277_00_AT_S.pdf
Arbor, Blade and Belts:
A 124010 NLA-TUBE ASSY-AR
B 124025 NLA-V-BELT HA
C 124013 NLA-ARBOR ASSY
D 2108181 Washer
E 2108202SM Bearing
F 2108257SM Washer
G 108371 NLA-SPACER-0.760
H 124044
J 124016 NLA-PULLEY
K 124017 NLA-PULLEY-DOUBL
L 8111037 NLA-KEY
M 2713504 Set Screw, 5/16"-18 x 3/8"
N 2717517 Jam Hex. Nut, 3/4"-16
P 124018 NLA-ARBOR ASSY
Q 124020 NLA-PULLEY-ARBOR
R 2715074 Hex Cap Screw, 3/8"-16 x 7/8"
S 124021 NLA-BLADE-MOWER
T 2715024 Hex. Cap Screw, 3/8"-16 x 5/8"
U 2720002 Lock Washer, 3/8"
V 2703004 Carriage Bolt, 3/8"-16 x 3/4"
W 2720002 Lock Washer, 3/8"
X 2717003 Full Hex. Nut, 3/8"-16
Y 2154534SM Idler Pulley
Z 703006 Carriage Bolt, 3/8"-16 x 1-1/2"
AA 2719001 Plain Washer, 3/8"
AB 2153073 Spacer
AC 2719002 Plain Washer, 5/16"
AD 2717510 Full Lock Hex. Nut, 3/8"-16
AE 124022 NLA-SUPPORT-IDLE
AF 124023 NLA-SUPPORT-IDLE
AG 124024 NLA-SUPPORT-IDLE
AH 2703005 Carriage Bolt, 5/16"-18 x 3/4"
AJ 2720001 Lock Washer, 5/16"
AK 2717001 Full Hex. Nut, 5/16"-18
Hitch Group
A 124041 NLA-HITCH ASSY
B 2722006 Cotter Pin, 1/8" Dia. x 1" lg.
C 2121184 Hex. Cap Screw
D 2720002 Lock Washer
E 721701 Spring Washer, 3/8"
F 2717515 Full Lock Hex. Nut, 3/8"-24
G 2118053SM Pin
H 1918196SM Spring Clip
J 159128 NLA-PULLEY-04.25
K 106674 NLA-LEVER ASSY-I
L 2705003 Hex. Cap Screw, 3/8"-16 x 2-1/4"
M 2717510 Full Lock Hex. Nut, 3/8"-16
N 106694 NLA-BRACKET-IDLE
P 2101096SM Idler Pulley
Q 2108151 "V" Belt
R 124042 NLA-SPACER
S 2705009 Hex. Cap Screw, 3/8"-16 x 1-1/2"
T 2719002 Plain Washer, 5/16"
U 2717013 Jam Hex. Nut, 3/8"-16
V 2106681SM Return Spring
W 2159129 Key
X 1729276SM Set Collar
Y 106695 NLA-BRACKET-IDLE
Z 2101096SM Idler Pulley
AA 106690 NLA-GUIDE-BELT
AB 2705016 Hex. Cap Screw, 3/8"-16 x 1-1/4"
AC 106731 NLA-SPACER-0.442
AD 2157127SM Conical Spring
AE 2722001 Cotter Pin, 3/32" Dia. x 3/4"
AF 106770 NLA-ROD & WASHER
AG 2106707SM Belt Stop
AH 2713001 Set Screw, 1/4"-20 x 3/8"
AJ 1729277SM Spring
AK 106768 NLA-ROD ASSY
AL 2717511 Full Lock Hex. Nut, 5/16"-18
AM 106730 NLA-COVER-PULLEY
AN 2159134 Nylon Washer
AP 2717525 Stop Nut, 5/16"-18
AQ 106710 NLA-HANDLE-CLUTC
AR 2122005SM Knob
AS 106728 NLA-CLIP-PULLEY
AT 106687 NLA-BRACKET-V .1
AU 124037 NLA-CABLE-.19DIA
AV 1708298SM Pin
AW 2715049 Set Screw, 3/8"-24 x 3/8"
Cutter Housing
A 124001 NLA-HOUSING ASSY
B 124009 NLA-PLATE-FRONT
C 2703005 Carriage. Bolt, 5/16"-18 x 3/4"
D 2720001 Lock Washer, 5/16"
E 2717001 Full Hex Nut, 5/16"-18
F 124026 NLA-COVER-SPINDL
G 2703005 Carriage Bolt, 5/16"-18 x 3/4"
H 2720001 Lock Washer, 5/16"
J 2717001 Full Hex. Nut, 5/16"-18
K 2705017 Hex Cap Screw, 5/16" -18 x 3/4"
L 2720001 Lock Washer, 5/16"
M 2717001 Full Hex Nut, 5/16"-18
N 124027 NLA-COVER-BELT
P 2715067 Std. Screw Taptite, 1/4"-20 x 3/8
Q 124028 NLA-BAFFLE
R 2715067 Std. Screw Taptite, 1/4"-20 x 3/8"
S 124029 NLA-CAP ASSY-END
T 124032 NLA-CAP ASSY-END
U 718037 NLA-NUT
V 2705012 Hex Cap Screw, 5/16"-18 x 5/8"
W 2720001 Lock Washer, 5/16"
X 2719002 Plain Washer, 5/16"
Some discussions about this attachment:
http://www.michaelstractors.com/forum/topic.asp?whichpage=1&TOPIC_ID=5552#41419
