Active Users: 14356 / Visits Today: 3929
Highest Active Users: 14356
1999 Mercruiser 502 EFI Engine Electrical Senders
Topic Locked
Posted - 03/05/2007 : 18:29:24
Coil Part #817378
Oil Pressure Switch Part #87-805605A_1
Oil Pressure Sender (used with 80psi gauge)Part #815425T
90AMP Fuse Part #79023A91 (Connects to starter & Battery)
Knock Sensor
Load Anticipation Circuit
MAP Sensor Connector
Connector to Distributor ()
Light Blue wires and connector?
EFI Harness to Starting Harness Connector
DLC Connector
Alternator Wires
Vent Hose
The purple violet wire?
Double red connector (connects Positive on EFI & Starting harness)
The distributor harness (two wire)
Mercathode
Relays and ECM:
Mercruiser Parts:
http://www.marinepartsexpress.com/mercruiser_central.htm?source=google&group=mercruiser&gclid=CPTX5KmUjpECFRuhFQodsVWjGg
http://www.go2marine.com/category.do?no=13800&view=item
Online Diagrams of Engine:
http://www.marinepartsexpress.com/Merc_Schematics/8.2L%20MIE%20MPI%20GEN%20VI%20GM%20502%20V-8/0L086013_0L674200/
Topic Locked
This page was generated in 0.05 seconds.
