Highest Active Users: 5
 Mfg #990434,435 Soveriegn 3012, B112
Posted - 03/09/2007 :  12:33:05  Show Profile  Visit B112's Homepage Send B112 a Private Message
Introduced in 1968.
Came with the 300421 0127-01 Briggs 12HP Engine
Model 434 and 435. The 435 had a hydrolift
Belts needed:
Variable Drive 54.0" pn 164080
Generator 39.1" pn 157524
PTO Belt 34" pn 164146 (34"L x 1/2"W)
42" Lawn deck 48" pn 108248
48" Lawn deck ?
Manual for your tractor:
http://www.simplicitytechpubs.com/6767PRINT/PDF_files/TP_100_1289_01_SV_S.pdf
Manual for your engine:
300421 Briggs and Stratton 12 HP
http://shop.briggsandstratton.com/BShopProductPage.asp?CatalogID=656F8AC4-B611-4BB3-95BF-A9C915B1275A&MECID=100&CategoryID=&lrid=&ProductID=56B2BC12-283C-11D4-8886-00B0D0203414#
Note: you will need 3 - 3/8"-2" Hex screws, Nut, washers and lock washer for the engine mounting bolts.
Brochures to collect:
IMPROVE YOUR LOT IN LIFE .....WITH SIMPLICITY, Form 868, 1969
Belt - Drive 166172
Belt - Generator 157524
Belt - P.T.O. 164146
Belt - Power Lift 157230
Engine Mfg Briggs & Stratton
Engine Model 300421
Engine Type 0127-01
Model Year 1967-68
42" GRADER BLADE
42" SNOW PLOW AND GRADER
46" DOZER BLADE
Here is a YouTube video demonstrating the Variable Speed Lever:
http://www.youtube.com/watch?v=WvW7W-uQLSY
BEVEL GEAR HOUSING
A 154062 Bevel Gear Housing, W/Bearings
B 154326 NLA-FITTING-PIPE
C 2164114SM Drive Shaft
E 2717517 Hex Jam Nut
F 2154137SM Shim (As Required)
G 2154138SM Shim
H 2154278 Oil Seal
J 2118011SM Ball Bearing
K 2154139SM Bevel Driven Gear
L 2725003 Key
M 2154279SM Needle Bearing
N 2118117SM Oil Seal
P 2157426SM Driven Shaft
Q 1612093SM Oil Seal
R 2154258SM Needle Bearing
S 2118134SM Retaining Ring
T 2118011SM Ball Bearing
U 2154040SM Bearing Clamp Plate
V 2720001 Lock Washer, 5/16"
W 2705012 Hex Capscrew, 5/16"-18 x 5/8" lg.
X 2154121SM Bevel Driven Gear
Y 2725003 Key
Z 2154026 Washer
AA 2154281 Hex Capscrew, 5/16"-18 x 3/4" lg.
AB 2154282SM Gasket
AC 154141 Housing Cover Assembly
AD 2726002 Pipe Plug
AE 728001 NLA-3/8 STREET E
AF 2726003 Pipe Plug
AG 164177 R.H. Side Plate
AH 2720006 Lock Washer, 7/16"
AJ 2705041 Hex Capscrew, 7/16"-14 x 1" lg.
AK 2707003 Hex Capscrew 1/4"-20 x 5/8" lg.
AL 2705042 Hex Capscrew 7/16"-14 x 1-1/4" lg.
AM 164179 NLA-PLATE-SIDE L
CLUTCH AND BRAKE GROUP
A 164089 NLA-LEVER-ASSY-P
B 2164094SM Rod Guide Assembly
C 2717511 Hex Lock Nut, 5/16"-18
D 164096 NLA-ROD-.312DIA
E 2717001 Hex Nut, 5/16"-18
F 2159106SM Tension Spring
G 2157300SM Foot Pedal Arm
H 2719001 Washer, Plain, 3/8"
J 2720002 Lock Washer, 3/8"
K 2717003 Hex Nut, 3/8"-16
L 2720002 Lock Washer, 3/8"
M 2108419 Bushing
N 2705030 Hex Capscrew, 1/4"-20 x 3/4" lg.
P 2720003 Lock Washer, 1/4"
Q 2717005 Hex Nut, 1/4"-20
R 157280 NLA-PEDAL ASSY-F
S 162098 NLA-PAD-PEDAL,SC
T 164210 NLA-ROD-.312DIA
U 2722009 Cotter Pin, 1/8" x 3/4" lg.
V 164143 NLA-BRACKET ASMY
W 157287 NLA-SPACER-0.493
X 164142 NLA-LOCK PARKING
Y 2164213SM Tension Spring
Z 2158196SM Special Washer
AA 2719001 Washer, Plain, 3/8"
AB 2722001 Cotter Pin, 3/32" x 3/4" lg.
AC 164189 NLA-ROD BRAKE
AD 2717003 Hex Nut, 3/8"-16
AE 2717022 Hex Nut, 7/16"-14
AF 2157282 Brake Drum
AG 2720006 Lock Washer, 7/16"-14
AH 2164111 Brake Band Assembly
AJ 1679358SM Brake Band
AK 2154133 Brake Lining
AL 724501
AM 164113 NLA-BRACKET-L .2
AN 2705005 Hex Capscrew, 3/8"-16 x 1" lg.
AP 2717003 Hex Nut, 3/8"-16
AQ 164212 NLA-BRACKET-SPRI
AR 2705007 Hex Capscrew, 5/16"-18 x 1" lg.
AS 2720001 Lock Washer, 5/16"
AT 2717001 Hex Nut 5/16"-18
ELECTRIC STARTER-GENERATOR SYSTEM
A 122041 Motor - Generator FOR SERVICE CONTACT YOUR LOCAL UNITED MOTOR SERVICE DEALER (DELCO-REMY)
B 122149 NLA-CABLE-# 6 X
C 2122023SM Terminal Cover
D 122140 NLA-WIRE-16GA ST
E 2157524SM "V"-Belt
F 2157004 Support Assembly
G 2720001 Lock Washer, 5/16"
H 2715048 Hex. Capscrew, 5/16"-18 x 3/4" lg.
J 2720001 Lock Washer, 5/16"
K 2717001 Full Hex. Nut, 5/16"-18
L 2705019 Hex. Capscrew, 5/16"-18 x 1-1/4"
M 122193 NLA-REGULATOR,VO FOR SERVICE CONTACT YOUR LOCAL UNITED MOTOR SERVICE DEALER (DELCO-REMY)
N 154002 Bracket
P 2705030 Hex. Capscrew, 1/4"-20 x 3/4" lg.
Q 2720003 Lock Washer, 1/4"
R 2717005 Full Hex. Nut, 1/4"-20
S 2157102SM Belt Tightener
T 2705017 Hex. Capscrew, 5/16"-18 x 3/4" lg.
U 2719002 Plain Washer, 5/16"
W 2717001 Full Hex. Nut, 5/16"-18
X 2122190 Battery
Y 122139 NLA-CABLE-# 6 X
Z 2122138 Cable (Battery to Ground)
AA 2705015 Hex. Capscrew, 1/4"-20 x 5/8" lg.
AB 2720003 Lock Washer, 1/4"
AC 2717005 Full Hex. Nut, 1/4"-20
AD 122142 NLA-INSULATION,B
AE 122143 NLA-INSULATION,B
AF 2122046 Starter Switch
AG 2720002 Lock Washer, 3/8"
AH 2717003 Full Hex. Nut
AJ 2720003 Lock Washer, 1/4"
AK 2717005 Full Hex. Nut, 1/4"-20
AL 2122131SM Ammeter
AM 122172 NLA-FUSE,20 AMP
AN 122144 NLA-WIRE-16GA ST
AP 122147 NLA-WIRE-GRND TO
AQ 1686702SM Ignition Switch
AR 2122111SM Keys
AS 122141 NLA-WIRE-18GA ST
AT 122171 NLA-WIRE-16GA ST
AU 122170 NLA-WIRE-16GA 09
AV 122183 NLA-CLIP-SPEED .
AW 122173 Battery Bracket
AX 122174 NLA-BOLT-J .250-
AY 2720003 Lock Washer, 1/4"
AZ 2718042 Wing Nut, 1/4"-20
BA 721508 Lock Washer, Int. 13/16"
BB 122199 Film (SIMPLICITY)
ENGINE AND DRIVE SHAFT
A ENGINE, Briggs & Stratton
B 157144 NLA-STOP-AXLE L
C 2720002 Lock Washer, 3/8"
D 2705010 Hex. Cap Screw, 3/8"-16 x 1-3/4" lg.
E 157556 NLA-SCREW ASY-EN
F 2717003 Lock Washer, 3/8"
G 2717003 Full Hex. Nut, 3/8"-16
H 2157316 Fuel Hose (Flexible)
J 154327 NLA-GUARD-CRANKS
K 157305 NLA-PULLEY-08.50
L 2154372 Hose Clamp (FOR SERVICE ONLY)
M 2154378SM Lock Nut
N 2157422 Coupling
P 2157424SM Special Washer
Q 2720002 Lock Washer, 3/8"
R 2717003 Full Hex. Nut, 3/8"-16
S 2705016 Hex. Cap Screw, 3/8"-16 x 1-1/4" lg.
T 2715043 Hex Capscrew, 3/8-16 x 2-1/2" lg.
U 2720002 Lock Washer, 3/8"
V 2719001 Plain Washer, 3/8"
W 2157016 Drive Shaft Assembly
X 2705016 Hex. Cap Screw, 3/8"-16 x 1-1/4" lg.
Y 2157424SM Special Washer
Z 2720002 Lock Washer, 3/8"
AA 2717003 Full Hex. Nut, 3/8"-16
AB 2705016 Hex. Cap Screw, 3/8"-16 x 1-1/4"
AC 2720002 Lock Washer, 3/8"
AD 2157427SM Key
AE 2154198ASM Drive Shaft Flange
AF 2715049 Cup point Socket Head Set Screw, 3/8"-24 x 5/8"
AG 2157422 Coupling
AH 157497 NLA-NIPPLE-PIPE
AJ 2726501 Pipe Cap, 3/8"
AK 2157485 Exhaust Muffler
AL 2157096 Decal, Fuel Tank
AM 2719001 Plain Washer, 3/8"
AN 157185 NLA-DECAL
AP 157131 NLA-DECAL-TO REM
AQ 2720002 Lock Washer, 3/8"
AR 2156176SM Shut-Off Valve
AS 157006 NLA-TANK-FUEL VE
AT 2156175SM Fuel Tank Cap
AU 2705053 Hex. Hd. Capscrew, 1/4"-20 x 1-3/4"
AV 2717005 Full Hex. Nut, 1/4"-20
AW 162060 NLA-STRAP-TANK
AX 2705006 Hex. Hd. Capscrew, 3/8"-16 x 2" lg.
AY 2157081SM Spacer
AZ 157126 NLA-SPACER-SOLID
BA 2715018 Hex. Hd. Capscrew, 1/4"-20 x 5/8"
BB 2719006 Plain Washer, 1/4"
BC 2720003 Lock Washer, 1/4"
BD 157355 NLA-SPACER-FLYWH
BE 157307 NLA-HUB-0.752IDX
BF 2805100SM Key
BG 157484 NLA-PULLEY-03.87
FRAME HOOD, GRILL & INST. PANEL
A 164003 NLA-SUPPORT-ASY
C 705019 Hex. Cap Screw, 5/16"-18 x 1-1/4"
D 717511 Full Lock Hex. Nut, 5/16"-18
E 717001 Full Hex. Nut, 5/16"-18
F 720001 Lock Washer, 5/16"
G 705012 Hex. Cap Screw, 5/16"-18 x 5/8"
H 164014 NLA-PANEL-SIDE R
J 164013 NLA-PANEL-SIDE L
K 718032 Nut Retainer
L 164117 Nut Retainer
M 715018 Hex. Cap Screw, 1/4"-20 x 5/8"
N 164232 NLA-INSTR PANEL
P 718032 Nut Retainer (Frame Cover)
Q 715093 Hex Cap Screw, 1/4"-20 x 1/2"
R 720003 Lock Washer, 1/4"
S 717005 Full Hex. Nut, 1/4"-20
T 164010 NLA-FRAME ASSY
U 720006 Lock Washer, 7/16"
V 705039 Hex. Cap Screw, 7/16"-14 x 1-1/2"
W 157057 NLA-WEIGHT-BASE
X 157060 NLA-SUPPORT-FRON
Y 157482 NLA-ANGLE & HUB
Z 715080 Hex. Cap Screw, 7/16"-14 x 1-1/2"
AA 720006 Lock Washer, 7/16"
AB 717022 Full Hex. Nut, 7/16"-14
AC 706003 Hex. Cap Screw, 7/16"-20 x 1-1/2"
AD 157065 NLA-FOOT REST
AE 157090 NLA-PAD-FOOTREST
AF 157089 NLA-PAD-FOOTREST
AG 705004 Hex. Cap Screw, 3/8"-16 x 3/4"
AH 720002 Lock Washer, 3/8"
AJ 717003 Full Hex. Nut, 3/8"-16
AK 164008 NLA-COVER & TUBE
AL 718022 Retainer Nut (Front)
AM 718030 Retainer Nut (Rear)
AP 715082 Hex Screw, Whiz-Lock Flange, 5/16-18 x 3/4
AQ 157488 NLA-BRACKET ASSY
AR 719002 Plain Washer, 5/16"
AS 720001 Lock Washer, 5/16"
AT 705019 Hex. Cap Screw, 5/16"-18 x 1-1/4"
AU 720001 Lock Washer, 5/16"
AV 705018 Hex. Cap Screws, 5/16"-18 x 1-1/2"
AW 164009 NLA-GRILLE
AX 122195 NLA-CLAMP-WIRE .
AY 714003 Self Tapping Screw, #810 x 1/2"
AZ 164028 NLA-PLATE-SIDE R
BA 164027 NLA-PLATE-SIDE L
BB 714005 Self-Tapping Screw #10-24 x 1/2" lg.
BC 714003 Self Tapping Screw, #10 x 1/2"
BD 164011 Hood
BE 718041 Nut Retainer(Rear)
BF 718024 Nut Retainer(Front)
BG 715037 Thumb Screw
BH 164120 NLA-PAD-FELT ADH
BJ 164121 Felt Pad
BK 166200 NLA-GUIDE
BQ 157020 NLA-GUIDE ASMY-R
BR 718032 Retainer Nut
BS 720003 Lock Washer, 1/4"
BT 164129 NLA-DECAL-HOOD S
BU 715018 Hex. Cap Screw, 1/4"-20 x 5/8"
BV 164042 Throttle Control
BW 164019 NLA-CONTROL-CHOK
BX 158475 Bowden Wire Clip
BY 157315 NLA-BRACKET-THRO
BZ 714021 Self Tapping Screw, 1/4"-20 x 5/8"
CA 122186 Clamp
CB 705015 Hex. Cap Screw, 1/4"-20 x 5/8"
CC 720003 Lock Washer, 1/4"
CD 719006 Plain Washer, 1/4"
CE 717005 Full Hex. Nut, 1/4"-20
CF 717007 Full Hex. Nut, #10-32
CG 710004 Mach. Rd. Hd. Screw, #10-32 x 3/8"
CH 714005 Self Tapping Rd. Hd. Screw, #10-24 x 1/2"
CJ 720003 Lock Washer
CK 166107 NLA-FILM-SIMPLIC
CL 164135 NLA-PLATE ASSY-E
CM 164137 Emblem "S"
CN 720007 Washer Lock
CP 717023 Hex .Nut #10-24
CQ 164191 Plug Button
FRONT WHEELS, AXLE, TIE ROD & STEERING
A 157505 NLA-WHEEL & TIRE
B 154397 Bearing Cone, w/seal
C 154393 Bearing Cup
D 108181 Washer
E 157506 NLA-WHEEL & BEAR
F 157490 Tire,
G 164247 Tube
H 157494 Spindle Assembly R.H.
J 157611 Spindle Assembly L.H.
K 8061012 Washer
L 8021010 Set Collar
M 713503 Cup Point Socket Head Set Screw, 5/16"-18 x 5/16" lg.
N 8021010 Set Collar
P 727002 Grease Fitting
Q 157616 Axle Assembly, Front
R 157618 Spacer
S 719004 Plain Washer, 1/2"
T 705037 Hex. Cap Screw, 1/2"-13 x 1" lg.
U 717518 Full Lock Hex. Nut, 1/2"-13
V 705016 Hex, Cap Screw, 3/8"-16 x 1-1/4" lg.
W 719001 Plain Washer, 3/8"
X 154177 Spacer
Y 720002 Lock Washer, 3/8"
Z 717003 Full Hex. Nut, 3/8"-16
AA 154289 Bearing
AB 157613 Arm Assembly, Steering, L.H.
AC 713006 Screw set Cup point, Square Head, 5/16"-18 x 1/2" lg.
AD 157427 Key
AE 717528 Full Hex. Lock Nut 1/2"-20
AF 720004 Lock Washer, 1/2"
AG 164272 Ball Joint
AH 164271 NLA-ROD-TIE .875
AJ 717016 Nut, 1/2"-20
AK 165078 Steering Wheel
AL 725003 Woodruff Key, #9
AM 713503 Socket Head Cup Point Set Sc rew, 5/16"-18 x 5/16" lg.
AN 713502 Steering Hd. Set Screw, 5/16"-18 x 1/4" lg.
AP 157259 NLA-SHAFT & FORK
AQ 153081 Spacer
AR 719001 Plain Washer, 3/8"
AS 720002 Lock Washer, 3/8"
AT 715030 Hex Cap Screw, 3/8"-16 x 3/4" lg
AU 154153 NLA-PIN-UNIV JNT
AV 157254 Bushing Assembly
AW 157258 Bushing
AX 157253 Pin Eccentric
AY 158399 Retainer Ring
AZ 720002 Lock Washer
BA 717003 Full Hex. Nut, 3/8"-16
BB 713012 Sq. Hd. Set Screw, 1/4"-20 x 3/4" lg.
BC 157302 NLA-STEERING BRA
BD 154258 Needle Bearing
BE 720001 Lock Washer, 5/16"
BF 705012 Hex. Cap Screw, 5/16"-18 x 5/8"
BG 8061012 Washer
BH 164263 NLA-ARM & SHAFT
BJ 164235 NLA-GEAR-STEERIN
BK 108182 Arbor Washer
BL 154487 Hub Cap
BM 717519 Gripco Center Lock 7/16"-14 DO NOT EXCEED 35 FT. LBS. OF TORQUE
BN 715026 Hex Cap Screw,
BP 717511 Full Hex. Nut, 5/16"-18
BQ 154264 Snap Ring
BR 157286 Retaining Ring
BS 157499 Drag Link
BT 154486 Outside Bearing
BU 157305 NLA-PULLEY-08.50
BV 157077 Steering Bushing
BV 156211 Hub Cap-Chrome Deluxe NOT ILLUSTRATED
HYDROSTATIC CONTROL GROUP
HYDROSTATIC COOLING GROUP
POWER TAKE-OFF
A 157285 Add to cart NLA-BRACKET-LAND
B 2103171SM Add to cart Bearing Housing
C 2154258SM Add to cart Needle Bearing
D 2727001 Add to cart Grease Fitting
E 157472 Add to cart Support Plate
F 2154233 Add to cart Pivot Rod. 5/8" Dia. x 6-13/16"
G 157270 Add to cart NLA-BOLT-U 1.344
H 2720001 Add to cart Lock Washer, 5/16"
J 2717001 Add to cart Full Hex. Nut, 5/16"-18
K 2722007 Add to cart Cotter Pin, 3/16" Dia. x 1-1/2"
L 2157266SM Add to cart Shaft Assembly, P.T.O.
M 2713503 Add to cart Set Screw, 5/16"-18 x 5/16"
N 1729259SM Add to cart Washer
P 2157116SM Add to cart P.T.O. Pulley
Q 2725003 Add to cart Woddruff Key #9-3/16" x 3/4"
R 2164146SM Add to cart "V" Belt
S 2157263 Add to cart Idler Lever Assembly
T 2154534SM Add to cart Idler Pulley
U 2719002 Add to cart Plain Washer, 5/16"
V 2705016 Add to cart Hex. Cap Screw, 3/8"-16 x 1-1/4"
W 157423 Add to cart NLA-`STOP-.125 X
X 157272 Add to cart NLA-SPACER-0.443
Y 2157288 Add to cart Retaining Ring
Z 2717510 Add to cart Full Hex. Nut, 3/8"-16
AA 2157262SM Add to cart Tension Spring
AB 164153 Add to cart NLA-GUIDE ASMY-R
AC 2717510 Add to cart Full Lock Hex. Nut, 3/8"-16
AD 1729277SM Add to cart Spring
AE 1729276SM Add to cart Set Collar
AF 2713001 Add to cart Screw, 1/4"-20 x 3/8"
AG 2164149 Add to cart Clutch Rod Assembly
AH 2719002 Add to cart Plain Washer, 5/16"
AJ 2717525 Add to cart Elastic Stop Nut, 5/16-18
AK 154362 Add to cart NLA-PIVOT BAR AS
AL 2719001 Add to cart Plain Washer, 3/8"
AM 2717510 Add to cart Full Lock Hex. Nut, 3/8"-16
AN 2122005SM Add to cart Knob
AP 2157121SM Add to cart Pulley
AQ 2805850SM Add to cart Key
AR 164152 Add to cart NLA-GUARD-BELT
AS 2705005 Add to cart Hex. Cap Screw, 3/8"-16 x 1"
AT 2719001 Add to cart Plain Washer, 3/8"
AU 2720002 Add to cart Lock Washer, 3/8"
AV 2717003 Add to cart Full Hex. Nut, 3/8"-16
AW 157050 Add to cart NLA-SUPPORT-BELT
AX 2705007 Add to cart Hex. Cap Screw, 5/16"-18 x 1"
AY 2720001 Add to cart Lock Washer, 5/16"
AZ 2717001 Add to cart Full Hex. Nut, 5/16"-18
BA 2161080SM Add to cart Belt Stop
BB 2705007 Add to cart Hex Capscrew, 5/16-18x1" lg.
BC 2720001 Add to cart Lock Washer, 5/16
BD 2717001 Add to cart Hex Nut, 5/16-18
BE 2719002 Add to cart Plain Washer, 5/16
BF 2164155SM Add to cart Handle Assembly
BG 157291 Add to cart NLA-ROD-.437DIA
BH 2705019 Add to cart Hex, CapScrew, 5/16"-18 x 1-1/4"
BJ 2717511 Add to cart Full Lock Hex. Nut, 5/16"-18
BK 2157273SM Add to cart Stud
BL 2717519 Add to cart Full Lock Hex, Nut, 7/16"-14
BM 154356 Add to cart NLA-LEVER ASSY-C
BN 121044 Add to cart NLA-PIN-LOOP .18
BP 2159134 Add to cart Special Washer
REAR LIFT DRAW BAR GROUP
A 154209 NLA-QUADRANT-LIF
B 157620 NLA-BEARING-LIFT
C 705031 Hex. Cap Screw, 3/8"-16 x 7/8"
D 705016 Hex. Cap Screw, 3/8"-16 x 1-1/4"
E 720002 Lock Washer, 3/8"
F 154210 NLA-BEARING-LIFT
G 705031 Hex. Cap Screw, 3/8"-16 x 7/8"
H 720002 I, ock Washer, 3/8"
J 157640 NLA-SHAFT ASSY-L
K 157624 Set Collar
L 713503 Set Screw 5/16"-18 x 5/16"
M 164122 Rear Lift Rod
P 154631 Adj. Yoke End
Q 157225 NLA-PIN-HEADLESS
R 722006 Cotter Pin, 1/8" x 1"
S 705052 Hex. Cap Screw, 7/16"-14 x 2-1/2"
T 154214 Tiller Lift.Assembly
U 8021010 Set Collar
V 713503 Set Screw, 5/16"-18 x 5/16"
W 157625 Front Lift Lever Assembly
X 157120 Key
Y 713502 Set Screw, 5/16"-18 x 1/4"
Z 157628 NLA-LIFT LEVER A
AA 157120 Key
AB 713502 Set Screw, 5/16"-18 x 1/4"
AC 154224 NLA-LATCH LIFT L
AD 723007 Roll Pin
AE 157013 Latch Rod
AF 722001 Cotter Pin, 3/32" x 3/4"
AG 154226 NLA-SPACER-0.493
AH 152006 Spring
AJ 154227 Thumb Button
AK 156209 Handle Grip
AL 153058 Pin
AM 8161045 Spring Clip
AN 166072 Arm Assembly
AP 705047 Hex. Capscrew, 7/16"-14 x 1-3/4
AQ 166076 NLA-SPACER-0.453
AR 720006 Lock Washer, 3/8"
AS 717022 Full Hex. Nut, 7/16"
AT 705041 Hex. Cap Screw, 7/16"-14 x 1"
AU 720006 Lock Washer, 7/16"
AV 166074 Draw Bar Assembly
AW 705042 Hex. Cap Screw, 7/16"-14 x 1-1/4'
AX 166075 Draw Plate
AY 715018 Hex Cap Screw, 1/4-20 x 5/8" lg.
AZ 720003 Lock Washer, 1/4"
BA 717005 Hex Nut, 1/4-20
BB 166110 Spacer
BC 166198 NLA-PLATE DECAL
BD 155037 Round Head Pin
BE 8161045 Spring Clip
BF 166197 NLA-FILM SAFETY
REAR WHEELS AND AXLE
A 105050 Washer
B 713002 Set Screw, 5/16"-18 x 3/8" lg.
C 157644 NLA-WHEEL
D 8261100 Hub Bolt
E 154208 L.H. Wheel Hub
F 159129 Key
G 715022 Set Screw, 3/8"-16 x 1-1/2" lg.
H 713004 Set Screw, 3/8"-16 x 1" lg.
J 717021 Hex. Jam Nut, 3/8"-16
L 105058 Bearing
M 152041 NLA-BEARING-1.12
N 153068 Bearing
R 152042 NLA-PLUG-0.385DI
S 713508 Control Traction Bolt 7/16"-20 x 1/2" lg. CAUTION: DO NOT EXCEED 25 ft. POUNDS OF TORQUE ON PART NUMBER 713508, REFERENCE LETTER (S), CONTROL TRACTION BOLTS.
T 164217 Differential Carrier
U 157120 Drive Key
V 154035 Axle Washer
W 164218 Differential Cover Must be replaced in pairs.
X 164219 Differential Gear
Y 725501 Hi-Pro Key
Z 154291 Retaining Ring
AB 154277 Axle Washer
AC 121311 Differential Pinion
AD 121083 Pinion Differential Spindle
AE 121084 Differential Spacer
AF 719002 Plain Washer
AG 164220 Differential Cover Must be replaced in pairs.
AH 715043 Hex. Cap Serew, 3/8"-16 x 2-1/2"
AJ 717510 Full Lock Hex. Nut, 3/8"-16
AK 705015 Hex. Cap Screw, 1/4"-20 x 5/8"
AL 720003 Lock Washer, 1/4"
AM 717005 Full Hex. Nut, 1/4"-20
AN 121190 Differential Cover Seal
AP 164221 Rear Axle
AQ 154065 Axle Collar
AR 154065 Axle Collar
AS 713002 Set Screw, 5/16"-18 x 3/8"
AT 157637 Tire 10-1/2 x 12
AU 157029 NLA-VALVE STEM &
AV 157636 NLA-WHEEL & TIRE
AW 157638 Tube (For Service Only)
AW 154505 Hub Cap Chrome NOT ILLUSTRATED
SEAT AND FENDERS
A 2156203 Seat Assembly
B 164041 NLA-SEAT DECK AS
C 2164029SM Seat Deck Bracket, Front
D 164050 NLA-ARM-ASSY-PIV
E 164018 NLA-CONNECTOR-MA
F 2159085SM Cushioin Connector, Front
G 2164145 Spring Clip
H 2720001 Lock Washer, 5/16"
J 2717001 Hex Nut, Full, 5/16"-18
K 703012 NLA-BOLT
L 2720001 Lockwasher, 5/16"
M 2717001 Hex. Nut. Full, 5/16"-18
N 2705012 Hex. Head capscrew, 5/16"18 x 5/8" lg.
P 2720001 Lockwasher, 5/16"
Q 2705016 Hex. Head Capscrew, 5/16"-18 x 5/8" lg.
R 2717510 Hex. Locknut, Full, 3/8"-16
S 2705005 Hex. Head Capscrew, 3/8"-16 x 1"
T 2720001 Lockwasher, 5/16"
U 2717001 Hex, Nut. Full, 5/16"-18
TRANSMISSION GROUP
A 166105 NLA-CASE SUB-ASS
B 166001 Gear Case
C 723018 Roll Pin, 3/8" x 1-1/4"
D 154271 Needle Bearing
E 166018 Needle Bearing
F 157519 Needle Bearing
G 166011 NLA-SHAFT-0.8125
H 166004 Gear-1st Interm.
J 166005 NLA-PINION-SLIDI
K 166014 Key
L 166013 Washer
M 166015 NLA-RING-RET EXT
N 166021 Oil Seal
P 166012 Shaft, Interm.
Q 166010 NLA-PINION & GEA
R 166016 Washer
S 166017 Retaining Ring
T 166066 Axle Tube Assembly
U 166006 Drive Gear
V 154096 Key
W 154097 Washer
X 166167 Washer
Y 154268 Snap Ring
Z 154269 Seal
AA 727002 Grease Fitting
AB 166043 Gear Case Gasket
AC 166103 NLA-COVER & BEAR
AD 166002 Gear Case Cover
AE 166019 Needle Bearing
AF 166028 NLA-SHAFT-0.557
AG 715019 NLA-SCREW SET SK
AH 166027 Shift Fork
AJ 154323 Spring
AK 154262 Shift Lock Ball
AL 166164 NLA-SHAFT & HAND
AM 166023 NLA-O-RING 0.424
AN 166029 Shift Stem
AP 717029 Hex. Jam Nut, 5/16"-24
AQ 166162 NLA-LATCH SHIFT
AR 726002 Pipe Plug, 1/4"
AS 726003 Pipe Plug, 3/8"
AT 728501 Street Elbow, 3/8" x 90ø
AU 705007 Hex. Capscrew, 5/16-18 x 1"
AV 705020 Hex. Capscrew, 5/16-18 x 2"
AW 720001 Lock Washer, 5/16"
AX 166097 NLA-PUMP & MOTOR
AY 166003 Motor Shaft Pinion
AZ 123144 Washer
BA 715103 Hex. Capscrew, 5/16-24 x 5/8"
BB 720001 Lock Washer, 5/16"
BC 166026 "O" Ring
BD 715064 Hex. Capscrew, 7/17-14 x 4"
BE 720006 Lock Washer, 7/16"
BF 717022 Hex. Nut, Full, 7/16"-14
BG 164224 Bushing
BH 166040 Spacer (R.H.Side)
BJ 166041 Spacer (L.H.Side)
Incomplete Capscrew, Washer, Lockwasher and Nut List
105050 Washer
108181 Washer
108182 Arbor Washer
123144 Washer
154035 Axle Washer
154097 Washer
154277 Axle Washer
157050 NLA-SUPPORT-BELT
164117 Nut Retainer
164152 NLA-GUARD-BELT
166013 Washer
166016 Washer
166167 Washer
705004 Hex. Cap Screw 3/8"-16 x 3/4"
705007 Hex. Capscrew 5/16-18 x 1"
705012 Hex. Cap Screw 5/16"-18 x 5/8"
705015 Hex. Cap Screw 1/4"-20 x 5/8" (2)
705016 Hex. Cap Screw 3/8"-16 x 1-1/4" (2)
705018 Hex. Cap Screws 5/16"-18 x 1-1/2"
705019 Hex. Cap Screw 5/16"-18 x 1-1/4" (2)
705020 Hex. Capscrew 5/16-18 x 2"
705031 Hex. Cap Screw 3/8"-16 x 7/8" (2)
705037 Hex. Cap Screw 1/2"-13 x 1" lg.
705039 Hex. Cap Screw 7/16"-14 x 1-1/2"
705041 Hex. Cap Screw 7/16"-14 x 1"
705042 Hex. Cap Screw 7/16"-14 x 1-1/4'
705047 Hex. Capscrew 7/16"-14 x 1-3/4
705052 Hex. Cap Screw 7/16"-14 x 2-1/2"
706003 Hex. Cap Screw 7/16"-20 x 1-1/2"
710004 Mach. Rd. Hd. Screw #10-32 x 3/8"
713002 Set Screw 5/16"-18 x 3/8" (2)
713004 Set Screw 3/8"-16 x 1" lg.
713006 Screw set Cup point Square Head 5/16"-18 x 1/2" lg.
713012 Sq. Hd. Set Screw 1/4"-20 x 3/4" lg.
713502 Set Screw 5/16"-18 x 1/4" (2)
713503 Cup Point Socket Head Set Screw 5/16"-18 x 5/16" lg. (3)
714003 Self Tapping Screw #10 x 1/2" (2)
714005 Self Tapping Rd. Hd. Screw #10-24 x 1/2"
714021 Self Tapping Screw 1/4"-20 x 5/8"
715018 Hex Cap Screw 1/4-20 x 5/8" lg. (3)
715022 Set Screw 3/8"-16 x 1-1/2" lg.
715030 Hex Cap Screw 3/8"-16 x 3/4" lg
715037 Thumb Screw
715043 Hex. Cap Serew 3/8"-16 x 2-1/2"
715064 Hex. Capscrew 7/17-14 x 4"
715080 Hex. Cap Screw 7/16"-14 x 1-1/2"
715082 Hex Screw Whiz-Lock Flange 5/16-18 x 3/4
715093 Hex Cap Screw 1/4"-20 x 1/2"
715103 Hex. Capscrew 5/16-24 x 5/8"
717001 Full Hex. Nut 5/16"-18
717003 Full Hex. Nut 3/8"-16 (3)
717005 Full Hex. Nut 1/4"-20 (4)
717007 Full Hex. Nut #10-32
717016 Nut 1/2"-20
717021 Hex. Jam Nut 3/8"-16
717022 Full Hex. Nut 7/16"-14 (3)
717029 Hex. Jam Nut 5/16"-24
717510 Full Lock Hex. Nut 3/8"-16
717511 Full Lock Hex. Nut 5/16"-18 (2)
717518 Full Lock Hex. Nut 1/2"-13
718032 Retainer Nut (3)
719001 Plain Washer 3/8" (2)
719002 Plain Washer 5/16" (2)
719004 Plain Washer 1/2"
719006 Plain Washer 1/4"
720001 Lock Washer 5/16" (6)
720002 Lock Washer 3/8" (6)
720003 Lock Washer 1/4" (6)
720004 Lock Washer 1/2"
720006 Lock Washer 3/8"
720006 Lock Washer 7/16"
720006 Lock Washer 7/16" (3)
720007 Washer Lock
721508 Lock Washer Int. 13/16"
2154026 Washer
2154281 Hex Capscrew 5/16"-18 x 3/4" lg.
2159134 Special Washer
2705005 Hex. Cap Screw 3/8"-16 x 1" (3)
2705006 Hex. Hd. Capscrew 3/8"-16 x 2" lg.
2705007 Hex. Cap Screw 5/16"-18 x 1" (3)
2705010 Hex. Cap Screw 3/8"-16 x 1-3/4" lg.
2705012 Hex Capscrew 5/16"-18 x 5/8" lg. (2)
2705015 Hex. Capscrew 1/4"-20 x 5/8" lg.
2705016 Hex. Cap Screw 3/8"-16 x 1-1/4" (5)
2705017 Hex. Capscrew 5/16"-18 x 3/4" lg.
2705019 Hex. Capscrew 5/16"-18 x 1-1/4" (2)
2705030 Hex Capscrew 1/4"-20 x 3/4" lg. (2)
2705041 Hex Capscrew 7/16"-14 x 1" lg.
2705053 Hex. Hd. Capscrew 1/4"-20 x 1-3/4"
2713001 Screw 1/4"-20 x 3/8"
2713503 Set Screw 5/16"-18 x 5/16"
2715018 Hex. Hd. Capscrew 1/4"-20 x 5/8"
2715043 Hex Capscrew 3/8-16 x 2-1/2" lg.
2715048 Hex. Capscrew 5/16"-18 x 3/4" lg.
2715049 Cup point Socket Head Set Screw 3/8"-24 x 5/8"
2717001 Full Hex. Nut 5/16"-18 (10)
2717003 Full Hex. Nut 3/8"-16 (9)
2717005 Full Hex. Nut 1/4"-20 (5)
2717022 Hex Nut 7/16"-14
2717510 Full Lock Hex. Nut 3/8"-16 (4)
2717511 Full Lock Hex. Nut 5/16"-18 (2)
2717517 Hex Jam Nut
2717519 Full Lock Hex Nut 7/16"-14
2717525 Elastic Stop Nut 5/16-18
2718042 Wing Nut 1/4"-20
2719001 Washer Plain 3/8" (6)
2719002 Plain Washer 5/16" (4)
2719006 Plain Washer 1/4"
2720001 Lock Washer 5/16" (11)
2720002 Lock Washer 3/8" (10)
2720003 Lock Washer 1/4" (6)
2720006 Lock Washer 7/16"-14 (2)
8061012 Washer (2)
1729259SM Washer
2154378SM Lock Nut
2157424SM Special Washer (2)
2157524SM "V"-Belt
2161080SM Belt Stop
2164146SM "V" Belt
Posted - 02/03/2011 :  23:38:09  Show Profile Send skunkhome a Private Message
New link for Early B112 and 3012 as follows:
http://www.simplicitymfg.com/document/index.cfm?doc=TP_400_1289_01_SV_S_LO.pdf
