 Simplicity 7013S Running Rough
Previous Page
coldr
Posted - 04/18/2020 :  10:35:27  Show Profile  Visit coldr's Homepage Send coldr a Private Message  Reply with Quote
I mowed with the tractor yesterday but only at about 2000 RPM and it was fine but a bit rough. Over that and it skips, sputters and backfires.
Denis
7013S
midnightpumpkin
Posted - 04/18/2020 :  11:29:45  Show Profile Send midnightpumpkin a Private Message  Reply with Quote
No the universal module will not fix a bad coil, but it will eliminate any issues with points or condenser.
You can buy one for just over $15 on e-bay, it takes 5 minutes to install and everything can be put back to orginal if it does not solve the problem.
Worth a try?
John U
coldr
Posted - 04/19/2020 :  19:08:18  Show Profile  Visit coldr's Homepage Send coldr a Private Message  Reply with Quote
It was a wise man who said “Try the easy things first.” Either the condenser or the the connection was bad. Changing it solved my problem. Thanks everyone for the help. Much appreciated.
Denis
7013S
Posted - 04/20/2020 :  14:15:23  Show Profile Send skunkhome a Private Message  Reply with Quote
Are you running the original engine in that tractor, Denis? My ole 13hp finally got too tired to press on leading me to have to repower to a Briggs 16 hp. Gosh that was 6-7 years ago. Hard to believe I’ve owned my 3414 for almost 13 years now.
Edited by - skunkhome on 04/20/2020 14:15:52
Posted - 04/20/2020 :  14:20:04  Show Profile Send skunkhome a Private Message  Reply with Quote
Watch that back firing...I’ve lost a few welsh plugs over the years. My brother pretty much killed his engine after blowing out his plug without knowing. Sucked in a ton of dust.
coldr
Posted - 04/21/2020 :  15:05:04  Show Profile  Visit coldr's Homepage Send coldr a Private Message  Reply with Quote
It is original as far as I know. I paid $1,000 for it 12 years ago. It came with a mowing deck, tiller, snow plow, molding plow, grading blade, rock rake (homemade), and sickle bar. Best money I ever spent. I did lose the welsh plug a few years back, but caught it in time and got away with honing the cylinder and replacing the rings.
Denis
7013S
Previous Page
