Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 7481 / Visits Today: 6960
Highest Active Users: 7481
 Looking for ideas
superbinder Posted - 07/04/2012 : 09:41:06
I picked up a 712h a while back that has problems. My bud from work loaned it to his neighbor who ran out of gas, so pulled it back to the barn, messing up the hydro. They then attempted a fix, loosing parts. Im wondering what my options are, since Larry and biggy mix and match, would a b-10 rear work or should i look for parts to fix the hydro?
7010b1 Posted - 07/11/2012 : 23:34:46
i have one that is just sitting here would trade ya yours for mine i dont know about mine tho been sitting for a while, but complete
larry8200 Posted - 07/05/2012 : 19:26:38
Yes, except for the engine, this tractor I have is identical.
superbinder Posted - 07/05/2012 : 16:30:08
Larry, i will check with the guy i got this gt from and see if he ever found the parts then let you know what i need. Is the hydro a sunstrand?
larry8200 Posted - 07/05/2012 : 13:03:59
So you need the pump/motor/control unit, and the fan/shroud some linkages etc. I have everything you need. PM if intereted
superbinder Posted - 07/04/2012 : 21:50:32
No, never drove a hydro. This is what i have to work with
larry8200 Posted - 07/04/2012 : 10:36:32
You can bolt a complete rear end (including BGB and side plates) from any large frame from the 700/725 on, BUT you will have a LOT of linkage work if you put anything but a Sundstrand hydro back in it.
If you are in New England I have a complete rear end (hydro and transaxle only) from a 7018H
You must not have run a hydro tractor before??, else you wouldn't be considering putting a geared transaxle in it.
This page was generated in 0.02 seconds. Snitz Forums 2000
