Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 626 / Visits Today: 626
Highest Active Users: 626
 My Favorite GT "Trailer"
larry8200 Posted - 12/18/2011 : 13:50:25
I think I put more hours on this trailer around the yard than I do on the road. And that is a lot. I have a hydraulic winch I wanted to put on it, but all said and done that would cost more to setup than a small 12 volt Warn winch brand new, maybe a lot more. The trailer is hooked to my 7112H pretty much full time, except when I'm using the blade, and while that 12 horse wont tow it up much of a hill with a full ton on it, it does just fine. I could almost get rid of my dump carts, almost.. :)
larry8200 Posted - 12/24/2011 : 16:29:24
I limit my trailers GVW to 2k, with no brakes thats really maxing my little Ranger, though the trailers hardware is rated 3k or more.
skunkhome Posted - 12/24/2011 : 15:36:54
Phil, does your trailer have brakes? Trailers in NH are required to have brakes if registered for 3,000 pounds or more.
no brakes
larry8200 Posted - 12/19/2011 : 11:32:15
Mine is just over 8' with the gate up. I wanted a 6' x 10' trailer but the only ones I could find had an expanded metal floor and the first thing I would have to done was put a PT floor in.
In retrospect, towing two large frame tractors and some accessories/attachments is asking a lot of my 4 cylinder Ranger, so its a good thing I didn't find a 6' x 10'. Actually I did find a nice all aluminum trailer that weighed 300 pounds less but cost 3 times as much. Would of been nice on the road, but maybe not so nice around the yard.
skunkhome Posted - 12/19/2011 : 10:46:02
mine is only a 5x8 actually 5x7'11" with gate closed, which aggravates me as I cant lay 8" stock straight in the trailer. It is strictly a one tractor trailer but has a capacity of 3500 lbs. It is about at the limit of what I can manhandle safely at my advanced age. I am sure I will have to rig up some help in the not to distant future.
larry8200 Posted - 12/19/2011 : 09:57:07
Hitch was drilled out to 3/4" when I got it, and its a standard 2" ball. If it wasn't drilled already I would have ordered a ball from Simpkicity with a 1/2" shank. The material on the tractors hitch is marginal for a 3/4" hole.
Talntedmrgreen Posted - 12/19/2011 : 06:07:46
What you got for a ball hitch on your tugger, there?
Hotwire7434 Posted - 12/18/2011 : 23:16:14
Nice trailer Larry. I have one similar I bought from a friend. It is 6 x 10 inside had to install a new wood floor otherwise just needs me to paint it. It has 4k axles though heavy duty. Love it and don't know how I got by without it. Merry Christmas.
Tom
larry8200 Posted - 12/18/2011 : 21:26:34
That looks like my Pro-pull trailer. What size and load capacity is it?
Load area is six feet by eight feet, cozy for two large frames. 3K axle/springs, rims and tires. Purchesed new from TSC with accessories for about $1,200.00
$18.00/year registered at 2K/lb. No brakes, no state inspection.
edit: trailer with accessorie weighs seven huidred pounds, toungue is 200 pounds unloaded. Ranger is rated 2K w/ 200 pound toungue
skunkhome Posted - 12/18/2011 : 18:38:53
simplicityacnut Posted - 12/18/2011 : 17:44:32
those tractors are real workhorses,cool
This page was generated in 0.94 seconds. Snitz Forums 2000
