Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 5306 / Visits Today: 5191
Highest Active Users: 5306
 Genny test and tune
Talntedmrgreen Posted - 11/06/2011 : 19:32:52
I've had this thing for months, and still haven't touched it. Mounted up the genny tonite...kinda a two-fold deal. It's heavy as hell, and I'm planning to use the genny hitch to base a bracket for my suitcase weights off of. For now, the unit itself is my counterweight. Also, since the loader machine will see intermittent use, I thought it the perfect candidate for being a genny machine, if the need arises.
I got a tip from someone that a 71" belt works great for the FDT/RBT genny combo, and it is spot on. Problem is...NO JUICE. I pulled the fuses, and will try new, but any other tips would be great! This thing is like brand new, and aside from a rust bubble or two on the belt cover, it looks unused. Even the hitch points still are unscratched.
Talntedmrgreen Posted - 11/07/2011 : 22:09:48
Wel, the flash worked great! Lots of juice in that old genny, and the engine responds well to the loads i could find to put on it. Very impressed! A great piece of equipment.
Talntedmrgreen Posted - 11/06/2011 : 22:55:49
Yeah! Been movin some sod and dirt. Works freakin awesome! Its dusty here and an hour after the pics were taken, the old girl had a well earned coating of crud on, in, under and through everything =]
I have another 2 yards or so to move, so Ill have to get some action shots and video.
larry8200 Posted - 11/06/2011 : 22:21:15
My setup is identical, except it AC livery, it has smaller than stock pulley so you dont have to run the engine WOT to get 240 but I wont to put stock back on it. can do pics.
Hey! has your BIG TEN made it outdoors yet? Tires sure dont look it! :)
Talntedmrgreen Posted - 11/06/2011 : 21:52:00
I was reading about that same process. I'll have to give it a try tomorrow, thanks!
Count Macula Posted - 11/06/2011 : 20:15:19
Maybe you just need to re-energize the generator.
With the generator running plug in a drill, with the drill in forward and the trigger depressed, spin the chuck backwards, be careful not to get your hand or clothing caught if the generator begins to make power.
This page was generated in 1.1 seconds. Snitz Forums 2000
