 a few more puzzle pcs
snohiker Posted - 06/26/2011 : 11:57:37
got the mid pto on the b1 yesterday now for the next pc of the puzzle theirs a clean spot were something was bolted on with the seat bracket im told tiller drive part or maybe a belt guard what do you guys think then off to find the rear lift
snohiker Posted - 06/29/2011 : 19:46:36
yup pm me
freddie Posted - 06/29/2011 : 13:03:28
this rob.
Talntedmrgreen Posted - 06/29/2011 : 12:05:45
Go here and look at figures 5 and 6 on Page 2. It's the perfect view....
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=heCBEN8aqI1rE3Cvh5kbp796Dq
Found a discussion on it here too:
http://www.michaelstractors.com/forum/topic.asp?TOPIC_ID=3258&SearchTerms=990174
Tiller reference:
http://www.michaelstractors.com/forum/topic.asp?TOPIC_ID=119&SearchTerms=990174
Talntedmrgreen Posted - 06/29/2011 : 12:00:45
I'll look for a pic, but the rectangular and cresent shaped belt guides shwon in the ebay ad listed above mount to the outside of the plate. The crescent piece sort of hangs over your smaller, tiller pulley on the BGB shaft. I have a couple at home and will try to remember to hold it up beside teh Big Ten for an example.
If I remember correctly, the spring loaded guide rod for the PTO also mounts through a hole on the rectangular peice...
snohiker Posted - 06/29/2011 : 11:47:22
there was something bolted to outside of the frame to the clean spot i think it has something to do with the tiller belt guides and i think that belt guard is easy enough to make thanks for the pic freddie the last is a rear lift
freddie Posted - 06/29/2011 : 10:45:29
here ya go rob, and what parts are you looking for? remeber i have tons of parts. this pic is a little diffrent but you get the idea.
snohiker Posted - 06/26/2011 : 22:04:48
pics would be great its nice to see what im looking for
Talntedmrgreen Posted - 06/26/2011 : 20:21:58
You need a 3-hole bar, and the 2-peice tiller bracket. I can take pics, but I don't have any mounted (no 32" tillers in the herd, currently) The bar goes on the inside of the plate, and the bracket on the outside, snuggled in around the tiller PTO pulley...the 'lil guy. Jon has half of it in his pic. You can kinda see the 3 hole bracket (black) in the upper RH side of his pic.
snohiker Posted - 06/26/2011 : 13:37:44
yup those r the holes
1014211 Posted - 06/26/2011 : 12:55:35
I think the two bolts at the right covered in mud are the ones you are pointing to on your tractor....
1014211 Posted - 06/26/2011 : 12:52:15
Yep, that is where the belt guard mounts on mine.
