Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 9952 / Visits Today: 8168
Highest Active Users: 9952
 Wet SNOW! What do you perfer?
3414HDuval Posted - 01/18/2011 : 09:22:09
Hey guys, i have a 3414H Baron and a 42 plow,
im debateing looking for a blower attach but i want all of your preferances,
in the wet snow which is the reason im home from school which is better, A Snowblower or a plow?
also how much help do wheel weights add?
3414HDuval Posted - 01/19/2011 : 09:36:04
N0 wheel weights for me EITHER! and i way 120
wlewis379 Posted - 01/19/2011 : 00:50:20
I have a long drive way and if I try running at a slower speed than wide open and full throttle I wouldn't even make it half way down the driveway. Especially if its wet. I did 20 inches of med dry snow last week. Today I plowed 6" of dry snow with a wet crust on top. What speed You plow at depends on the task at hand. Is it a short run or a long run I have to do both. I use different speeds for each.
If I am just trying to push the banks back I ease into it and lift the plow as I push it forward. I have been using the 7790 diesel for 20 years and it does a very good job plowing.
Every time I plow with it, it never ceases to amaze me how much snow that garden tractor can push. NO wheel weights just tire chains on it and my fat hind end.
larry8200 Posted - 01/18/2011 : 22:27:48
Michael, get yourself a 32 cid hydro with a 42" blower & running boards and you'll never look back! Of course you can just stay by the fire....
B112 Posted - 01/18/2011 : 21:58:06
Michael, I fly wide open too...not always full throttle, but always 3rd gear. Speed has always been my friend. When my piles really get big I can often slam them, pack them, and begin to drive up them, pushing snow over the incline. Just gotta make sure to stop before going over the top. =] The 10 horse has never waved the white flag...I cant imagine what a 14 or 16 will do.
Well good to hear I'm not the only one... except with 3 to 4 BGB's to repair, two transaxles, and a few engines... I got to start being gentler and getting the right implement and weight behind these machines!
skunkhome Posted - 01/18/2011 : 21:40:30
 Wet SNOW! What do you prefer?
Staying inside with my feet propped up in front of the fire!
Talntedmrgreen Posted - 01/18/2011 : 20:22:07
acdad Posted - 01/18/2011 : 20:16:19
Originally posted by Cvans
I guess my 42" blower works on everything up to and including half water and half snow. This is one of the reasons I'm not interested in a two stage blower. From what I've seen and heard they don't seem to digest the slush as well as the single stage. I suppose I better get under the table after that last statement.
I agree with you Chris. My single stage with eat through all the wet stuff I can give it, but my walk behind 2 stage gets all clogged up with anything wet.
B112 Posted - 01/18/2011 : 20:03:48
Originally posted by 3414HDuval
No i dont SLAM!i push
I guess I am really hard on my machines. That should change with what I'm hearing. I tried that with my powerMax and it stops dead in a snow bank, it's a jolt.
3414HDuval Posted - 01/18/2011 : 19:54:05
No i dont SLAM!i push, it is a Hydro so i dont have gears just alot of RPM and a little on the hydro puahed all this wet snow like nothing, when i get to pile up the snou i lift the blade high and hit the pile (not with speed) so i push the top back further and then push moreunder where i pushed pervisuly,
with my 14 HP Briggs with original piston and rings in it i run her almost full throttle shes old but not tired yet,!
larry8200 Posted - 01/18/2011 : 16:33:07
I'll have to join you there, My 42" blower has yet to meet it's match, I wouldn't trade it for anything, it can take a lot of power to keep the necassary volume going through it though.
It would be nice to get tha cab mounted...
Cvans Posted - 01/18/2011 : 16:21:04
larry8200 Posted - 01/18/2011 : 16:01:23
Originally posted by B112
Do you slam into the snow to push it? I usually use 3rd gear and use speed to get big piles of snow, then lift the blade a little to push the piles larger. I pretty much have handled all snows of my area with a plow, but the last one of 14" was best handled by the snow blower. I'll be testing the snow blower more often and will see how it does on wet snow. I may consider making the wheels like I saw in the other post for the snow blower.
Nope, I dont slam, just push. A lot of wet heavy snow works the engine real hard with the blower and pulls non simplicity belts apart at the join
Heres after a half hour in 6" of heavy snow thats been getting rained on the last hour. YUK
B112 Posted - 01/18/2011 : 15:48:03
3414HDuval Posted - 01/18/2011 : 15:16:37
yes larry, i just came from pushing that 8 inch of Snow/slush top with mine and she did great,!
i plow 3 driveways, and she did great on all of them except she did not like to turn this is one of the houses i do
anyway u say it is harder on your tractor than you would like, what do u mean by this?
larry8200 Posted - 01/18/2011 : 14:24:15
My 42" snowthrower works OK on wet snow but it really works my 3416H harder than I like too. I've done 5" of slush with it. Going out to do 8" of wet snow right now, I dont anticipate any problem.
