Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 1112 / Visits Today: 1112
Highest Active Users: 1112
 whatcamacallit
ATF Posted - 07/30/2010 : 08:07:12
Okay what is the rod that goes into the rear lift called. I've seen guys put some kind of steel? rod in the rear lift to extend it further up and out. It appears to have a hole drilled through it. I've tried to find something that will fit, but haven't found anything so far. It seems to be very similar to the one on my Cub Cadet 1650 lift
ATF Posted - 07/30/2010 : 22:14:49
I'm going to find one about 12 inches and drill several holes in it. the 5/8 sleeve for the pin on my new lift was near impossible to find. I eventually found a 5/8" X 2 3/4" axle bushing from a grasshopper. There is no thick wall pipe that is 5/8 inch, none I could find. The pin is 5/8" the holes in the implements are 5/8 of an inch so I HAD to have a 5/8 sleeve to pin them
skunkhome Posted - 07/30/2010 : 19:25:22
The original bar is about 8" overall. It is called a "plow lift pin" Go to the Simplicity web site and key in "990202". I made mine out of a steel stake for Diamond horseshoes.
ATF Posted - 07/30/2010 : 17:56:02
It's the bar/rod that goes into the lift over 1 inch in diameter, the big rusty looking hole in the picture. I've seen some 4-6 inches long and others over a foot with a chain
freddie Posted - 07/30/2010 : 17:52:52
ATF do you meen for the implaments in the rear.
This page was generated in 0.84 seconds. Snitz Forums 2000
