 ranger sending unit
3414HDuval Posted - 03/25/2011 : 14:46:37
doese anyone know how to test a sending unit to see if its bad or not?
thanks!
BRAD1975 Posted - 03/30/2011 : 22:34:11
if you're saying that the fuel pump works but the float level does not...then start with the float ..use a digital ohm meter and check that it has a smooth curve of resistance with no gaps
if it shows well then you need to check the ground and associated wiring ..its rarely a gauge problem...id say 90% usually the sender...10% wiring...and 9 0ut of ten times the wiring problem is bad grond
skunkhome Posted - 03/30/2011 : 21:23:25
That is so funny...visiting two dedicated sites but getting more answers from a garden tractor site. Got to love it.
3414HDuval Posted - 03/30/2011 : 21:02:52
it is a 1988 and its the fuel unit the unit works but the gauge doese not
ByronC Posted - 03/30/2011 : 18:36:29
What year model is the Ranger?
BRAD1975 Posted - 03/29/2011 : 17:55:25
what exactly is the problem?...does your gauge stay at full?..does it stay at empty?..or are you having fuel pump trouble?..
doyoucesp1965 Posted - 03/28/2011 : 20:44:24
Most vehicles have 4 wires..A ground for the fuel pump as well as a ground for the fuel Guage. Most operate off a 5 volt referance signal..that is why one always lites dimely with a test light and at times may even blink..Get a good ground and use a multimeter! can then also use it to ohm it out for breaks or hot spot's in the spring as mentioned above..Test light's in this day and age are not a good thing to use..Can burn things out Quick and in a hurry! Good luck and cute truck!
3414HDuval Posted - 03/28/2011 : 17:38:29
yes im on two of those fouerms but they dont reply back as fast as you all here on this fourm, honestly this being my first fourm i joined i seam to (get more done) by coming here. and it is the fuel sending unit
Richard L. Posted - 03/28/2011 : 13:54:43
I knew it was something like that.
stangstud1 Posted - 03/28/2011 : 11:34:39
A website I go to once in a while, is therangerstation.com. Lots and lots of valuable information. Keep that Ranger on the road!!
Richard L. Posted - 03/27/2011 : 10:42:12
You've been given some pretty good answers for such a vague question. Inquiring minds want to know what you're working on specifically. If you really want help with your Ranger try Ranger.com or whatever Ford sites that are that relate to your truck.
ByronC Posted - 03/27/2011 : 10:31:55
What sending unit is it? Fuel, Oil Pressure? or what? Does it operate a gauge or a light?
3414HDuval Posted - 03/27/2011 : 09:44:14
the unit is out of the truck, and i would like to check for power
BRAD1975 Posted - 03/27/2011 : 00:01:01
heres a website I use for reference...some models will show wiring diagrams and some wont...Im not sure if it works from outside canada
use the username "tech" and password "tech"......go to "ARRC" and the rest is easy to navigate
http://search.ebscohost.com/Login.aspx?lp=login.asp&ref=&authtype=ip,uid
BRAD1975 Posted - 03/26/2011 : 23:57:30
its basically a variable resistor...use an ohm meter if the part it out
if its still in the tank youre outta luck and can only check for broken wires or good ground
Richard L. Posted - 03/25/2011 : 17:13:01
What are you trying to test? Generally disconnecting the wire and grounding it will peg the gauge.
