Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 10 / Visits Today: 10
Highest Active Users: 10
 Carburetor Trouble
Tractorpuller101 Posted - 04/25/2007 : 17:15:30
Hello anyone who knows about Tecumseh carburetors. I can't get mine to stop leaking. I will post a picture as soon as I can. You can email me at rockndb@gmail.com or reply to this posting.
Thanx,
Tractorpuller101
B112 Posted - 12/12/2007 : 08:23:27
I was replying to Dan's comment right above mine. I think you've since started the post on mounting tires. Over the holidays and into January (more Jan), you'll see me trying to do some organization to the site. It's just busy these days for me.
Originally posted by B112
Hi, actually I don't have a discussion on how to get a tire back on it's rim. Please start one and I'll definitely join in!
????? How do you get a tire back on its rim? ????
bangor3142 Posted - 12/12/2007 : 07:53:58
HELLO THERES A COUPLE WAYS 1 IS BUY WHAT THEY CALL A CHEATA THIS PROBELLY THE BEST WAY BUT IF YOU PUT A BEAD OF BEARING GREASE ON BOTH SIDES OF RIM AND PUT A ROPE AROUND TIRE TO HOLED THE BEADS TIGHTER TO THE RIM THEN TAKE THE VAVLE CORE OUT AND PUT YOUR AIRHOSE TO VAVLE STEM WITH AN AIR VAVLE ON THE HOSE THIS WILL USALLY DO THE JOB
skunkhome Posted - 12/11/2007 : 23:38:59
olcowhand Posted - 12/11/2007 : 19:13:12
With the carb having been flooding, your spark plug is likely fuel fouled. Put in a new spark plug & give a try. If it doesn't fire, spray a short burst of aerosol carb cleaner into the carb throat & quickly attempt to start. If she fire, then you still have a carb issue most likely. To check spark, leave plug out with wire connected with plug base against head...away from plug hole. If no sparky, you have electric issues.
bangor3142 Posted - 12/11/2007 : 17:18:07
HELLO I FOUND ON SOME CARB'S THERE IS A TINY PIN HOLE ON THE SIDE OF THE CARB IF IT'S CLOGGED THE CARB WILL LEAK OR IF FUEL IS LEAKING OUT OF BOWL AND GASKET IS GOOD TURN BOWL A QUATER TURN
B112 Posted - 08/21/2007 : 22:59:50
Tractorpuller101 Posted - 08/20/2007 : 10:43:43
Just a follow up it turns out that the bowl was mis bent and unadjusted. I had it serviced and sold iy about 3 or 4 months ago. Thanx again for your help!
P.S. Do you already have a forum on the best way to get a tire back on its rim?
Tractorpuller101 Posted - 05/10/2007 : 07:13:20
You forgot compression.
B112 Posted - 05/08/2007 : 22:19:22
I've activated the following topic I've worked on:
http://www.michaelstractors.com/forum/topic.asp?TOPIC_ID=64
Go to the last link and read "Determining why it won't start"... the writer describes the "FAST Method" which is to check:
1. Fuel
2. Air
3. Spark
4. Timing
Good luck. Let us know how your project turns out.
Tractorpuller101 Posted - 05/08/2007 : 20:20:18
So are you suggesting that I squirt some gas in the cylinder and put the spark plug in to try to get a kick out of the engine?
I think its getting spark because i took the plug out and it sounded a lot different.
B112 Posted - 05/07/2007 : 06:29:13
These might be silly questions, but are you both getting gas in the engine and getting a spark? Is the engine even giving a kick? I've found that as long as you have electrical working, if you can get gas in the carburator the engine will give a kick. If you have a gas supply problem on the gas, the engine kicks but will not keep going.
Tractorpuller101 Posted - 05/06/2007 : 19:51:35
i fixed the leak but it still wont start. any ideas?
B112 Posted - 05/05/2007 : 18:06:52
Your definitely welcome. Feel free to let us know how your projects are going!
Tractorpuller101 Posted - 05/05/2007 : 10:21:02
Thank you so much Michael. I found a PDF manual on one of the links you left. I think I found the problem!! I think my needle was upside down!
B112 Posted - 04/28/2007 : 20:59:09
Here's an article on your carb adjustment:
http://forums2.gardenweb.com/forums/load/lmower/msg0321430015229.html
This page cross references a bunch of engines (says your engine is 7hp):
http://home.gwi.net/~spectrum/snowengines.html
This page says your engine is a 6hp:
http://www.perr.com/forum/viewtopic.php?p=4238&sid=f92b38a24503723e8deae41c0b5564ac
I recommend the last forum for engine info, as the owner runs it like or for school on small engine rebuiling.
