Highest Active Users: 7
 2003 Cover-IT repairs (46L x14W 'x10'H)
B112 Posted - 11/09/2020 : 16:03:39
So I'm going to start a post on how I am repairing my cover-it. I limped along for a number of years after a 33" of snow collapsed the roof (looked like 4' in some drifts). The rest of the unit held up, but 13 ribs failed. More pictures to come and the design to be documented.
https://www.geofffox.com/MT/archives/2013/02/09/2013-blizzard-snow-totals-for-connecticut.php
The original unit looked like this in 2003:
Tractors around the boat:
Then we had a snow which as you can see all the roads were covered and not plowed. There was no way to get to Cover-It to remove snow:
This is the unit after the snow was removed from the cover, the boat pulled out and the roof jacketed back up. From 2013 until 2018 (five years), I limped along with metal stressed roof ribs:
The unit was assembled in approximately 2003 to house my boat and it became the tractor cover-it also. I'd sneak those little buggers next to my 27' boat and behind it because I was planning to get a bigger boat (never happened.. got married and had kids).
So I purchased this pipe bender from Harbor Freight and bent one tube so far (Electrical EMT pipe - I am looking to replace with schedule 40 with the swedge 3" ends when I can get a fair price for purchase and shipping).
The cover-it bent all of the upper ribs, the all but one of the straight pipes were straight:
This is a picture of one of the ribs repaired. Generation one of the repair.
I am straightening the frame using 2x4 wood and EMT pipe clamps screwed to the boards. To fit my boat back into this unit, I will need to make trusses and I am still pondering that design. So far I plan to firm up the unit with select areas of wood and restore the ribs, but I am planning to add wooden rafters which will hold the walls up firmer and I may be able to mount ladders and other equipment on the walls.
(I'll edit the first post as I go... so far above is what I got.)
B112 Posted - 06/15/2026 : 10:16:35
Still in progress, cover still on as of today, bad wind it blows off.
Cvans Posted - 06/07/2026 : 00:34:40
How did your project turn out. I hope it went well for you.
B112 Posted - 04/02/2026 : 12:01:49
Yes I do use some non-forum friendly words when I trip on something.
Cvans Posted - 02/26/2026 : 15:41:41
If there is anything I do not like it is cleaning up the shop. I don't envy you. I usually wait until I'm tripping over stuff on the floor.
B112 Posted - 12/05/2025 : 16:23:14
It all a factor of how quickly I can clean out another garage :) That project will need some nice space to drive it fast.
Cvans Posted - 11/30/2025 : 02:10:55
Sounds like a good idea.
B112 Posted - 11/19/2025 : 14:19:50
I've not pulled the trigger on a new engine yet... still looking for the best solution.
Cvans Posted - 11/02/2025 : 01:07:59
Onan's are good engine when they are running but when they break down you just about have to visit the banker to afford parts. I have an Onan standby generator that I revived this summer. Very nice machine as it runs at only 1800 rpm and is very quiet. I dread the day it breaks down though.
Does your kit come with a B&S engine? Don't know too much about the newer ones. My 6-year-old Ferris Zero turn has a B&S V twin and it has been flawless. Hope I didn't just jinx myself!
B112 Posted - 10/22/2025 : 21:34:38
For the PMAX. I am looking at one of the bolt in kits and selling the running Onan. I am not fond of having to pull it and then fix it. Or the option of the pulley system I couldn't find time to complete. If I have a turn-key solution, it will get done. I am sorry to hear your back is giving you difficulties. Mine is slowing me down, but not stopping me yet. Still too many projects...
Cvans Posted - 10/20/2025 : 22:15:17
I like working on Boats and old OMC motors. Unfortunately my back has deteriorated to the point where I can no longer do it.
What engine are you planning to put in the Pmax. Diesel??
B112 Posted - 09/28/2025 : 20:55:29
Hi - Yes, it's going to be an ongoing project :) Other projects get in the way. For example, I need to clean out a good working bay and will be renting that in the next few weeks, a second boat is in the process of getting restored and I may work on an engine transplant on the PMAX. So far so good on the cover, in some ways I'd rather it blow off and then shovel off the snow.... The snow storm which collapsed it was worse than re-attaching the cover.
Cvans Posted - 09/21/2025 : 20:36:34
This is getting to be quite the project and it's looking like mother nature has the upper hand. Even the larger hoop buildings here have a hard time surviving.
B112 Posted - 07/05/2025 : 11:35:13
laugh, spoke too soon. Heavy winds in the northeast ripped the cover at the points I am securing again Thursday night. Fortunately, it was easy to reattach, still going to wait for the fall for the next fix up. The pipes are holding up, but I want to make sure they are secured more before we put on the shrink wrap. More to come.
B112 Posted - 07/01/2025 : 13:25:24
The latest cover is holding up well. I am going to model my changes relative to what I see boat repair shops using. Unfortunately I didn't start with a round top unit and the structure is not as strong as some of the others I'm seeing. You'll be see some updates later in the summer or fall when the kids get back in school. Right now is boating season and rental property work.
Cvans Posted - 06/29/2025 : 03:52:34
Have you ever thought about riveting tin to those pipes? Tin like they use on pole buildings. A pop rivet gun or self tapping screws. I would think that that would hold up and maybe not a whole lot more expensive. Some times atter hail has gone through you can pick up good used tin for cheap.
