Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 6786 / Visits Today: 1454
Highest Active Users: 6786
 Gas In The Oil
lilypad Posted - 07/03/2017 : 22:48:49
My Husqvarna rototiller was acting as if it was getting too much gas. When I checked the oil gasoline poured out. It has a Briggs and Stratton 950 series engine. Can I assume that the problem is with the carb?
skunkhome Posted - 07/06/2017 : 17:04:20
I'm sure its the carb.
lilypad Posted - 07/05/2017 : 23:24:21
It has a fuel shut off that I think I forgot to turn off. I will change the oil and see how it goes. Thanks for all the suggestions.
ByronC Posted - 07/05/2017 : 07:19:45
Does it have a block mounted fuel pump?
Cvans Posted - 07/04/2017 : 21:37:32
I have to agree with Dave's advice. You might consider a fuel filter between the tank and carb.
B10Dave Posted - 07/04/2017 : 18:31:16
Probably. Change the oil and take off the carb to see if the needle is sticking open. A shut off on the fuel line between tank and carb would also be a good idea. Good luck....Dave
