Michael's Tractors (Simplicity and Allis Chalmers Garden Tractors) Active Users: 9383 / Visits Today: 662
Highest Active Users: 9383
 dan test
B112 Posted - 11/26/2008 : 16:25:18
Dan, I'm having the same problem. I am wondering if they are blocking usage in some way. I can past that link in my browswer and it works fine.... I'll try some more stuff.
olcowhand Posted - 11/27/2008 : 18:31:01
Daniel, I thought you would just copy the image onto your profile...did not realize you were still trying to run through photobucket.
See, there you go....not aware of doing it that way. LOTS that I don't know to do on computers!
skunkhome Posted - 11/27/2008 : 18:10:38
B112 Posted - 11/26/2008 : 19:03:56
np - cool ... Have a good Turkey Day all!
olcowhand Posted - 11/26/2008 : 18:31:15
That deserves a toast! This problem was nearly driving me to drink heavy! And I don't even drink!
olcowhand Posted - 11/26/2008 : 18:29:16
THANKS!
B112 Posted - 11/26/2008 : 17:21:52
Ok, how's that?
B112 Posted - 11/26/2008 : 17:15:14
I made a test.htm file and it works fine... When I look at the source resulting from building this page, I see it not formating correctly. Need to investigate that further.
olcowhand Posted - 11/26/2008 : 16:43:30
Tried shorter one, using IMG file, the "previews" shows the pic & siggy text fine, but it won't add it when I hit submit.
Here's new:
IMG http://i8.photobucket.com/albums/a31/olcowhand_in_ky/me.jpg /IMG (removed brackets above)
B112 Posted - 11/26/2008 : 16:32:21
Correction, the SNITZ system is parsing your URL incorrectly. That will be a little work to fix. My guess is that your URL is too long. Can you try a shorter filename?
